- To:
- Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
- Date: Fri, 2 May 2008 10:34:38 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=RPvepFApvUr0s4Qe3Gb+t3CmNR11492DzqhMADohZH7fO8e3Kuio1Lhvp8ZJmyARi4nX2dV7i3d69zQZSzVKgarcQFbF6bue+4dVJeWwATkMznDZ59aHrVNEh4CYMy9rVhAXK+iQm9Jdmh/Z5dYbLn6wAOMvdGwCpS2aO/bziWg=
There is a need to compile all the libraries in vc 9.0
I've done this already. Check out:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows/
You'll be the beta user of this page and libraries.
Don't forget to get vc 9.0 boost.
I hope that this will solve your problems,
Ophir
On 5/1/08, Wesley Smith <> wrote:
Alright,
I'm still having massive issues with CGAL under VS2008. I tried compiling:
C:\Program Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
I get these errors:
1>Linking...
1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved
external symbol "__declspec(dllimport) public: void __thiscall
std::_Container_base::_Orphan_all(void)const "
(__imp_?_Orphan_all@_Container_base@std@@QBEXXZ) referenced in
function "public: class std::vector<short,class std::allocator<short>
> & __thiscall std::vector<short,class std::allocator<short>
>::operator=(class std::vector<short,class std::allocator<short> >
const &)" (??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
external symbol "__declspec(dllimport) public: __thiscall
std::_Container_base::~_Container_base(void)"
(__imp_??1_Container_base@std@@QAE@XZ) referenced in function "public:
__thiscall std::_Vector_val<short,class std::allocator<short>
>::~_Vector_val<short,class std::allocator<short> >(void)"
(??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
std::_Container_base::_Container_base(void)"
(__imp_??0_Container_base@std@@QAE@XZ) referenced in function
"protected: __thiscall std::_Vector_val<short,class
std::allocator<short> >::_Vector_val<short,class std::allocator<short>
>(class std::allocator<short>)"
(??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe : fatal
error LNK1120: 3 unresolved externals
These are my linker libs:
"C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
I can't think of anything I'm missing. Has no one come across this
symbol before???
thanks,
wes
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/01/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ophir Setter, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Andreas Fabri, 05/02/2008
- RE: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Dave McVicar, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Fernando Cacciola, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/03/2008
