cgal-discuss - Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
  • To:
  • Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
  • Date: Fri, 2 May 2008 15:26:20 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=ZfZ+GfYtfOdudH08nS16ZLMjnYKaVtebr80vPibw0xrZhgXJ05yBeDMmoZLpX5EdXtKdC8yqiy2W7lp8T+acAqtArUSw+IPJrA2N1M2SKPiVADm5ndW7tPvroejD0LUPen2jZZD+X8FuvpMvdtBROpa6+eSTgHAoX3bagsNnI2Y=
Did you compile boost for vc 9.0? I got the _Container_base error using boost not compile in vc 9.0 and not because of CGAL. Anyway, I now run CGAL and boost on VC9 with no problems.
On Fri, May 2, 2008 at 10:56 AM, Wesley Smith <> wrote:
Hi Ophir,
Many Thanks!  I'll try this out and get back to the list.  I had
though I had compiled CGAL with vc9, but I also have previous version
of vc on my system, so it's entirely possible that the build process
used on of those instead.  Hopefully that's the case.
wes
On Fri, May 2, 2008 at 12:34 AM, Ophir Setter <> wrote:
> There is a need to compile all the libraries in vc 9.0
> I've done this already. Check out:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows/
> You'll be the beta user of this page and libraries.
> Don't forget to get vc 9.0 boost.
> I hope that this will solve your problems,
> Ophir
> On 5/1/08, Wesley Smith <> wrote:
> > Alright,
> > I'm still having massive issues with CGAL under VS2008.  I tried
> compiling:
> > C:\Program Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
> > I get these errors:
> > 1>Linking...
> > 1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved
> > external symbol "__declspec(dllimport) public: void __thiscall
> > std::_Container_base::_Orphan_all(void)const "
> > (__imp_?_Orphan_all@_Container_base@std@@QBEXXZ) referenced in
> > function "public: class std::vector<short,class std::allocator<short>
> > > & __thiscall std::vector<short,class std::allocator<short>
> > >::operator=(class std::vector<short,class std::allocator<short> >
> > const &)" (??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
> > external symbol "__declspec(dllimport) public: __thiscall
> > std::_Container_base::~_Container_base(void)"
> > (__imp_??1_Container_base@std@@QAE@XZ) referenced in function "public:
> > __thiscall std::_Vector_val<short,class std::allocator<short>
> > >::~_Vector_val<short,class std::allocator<short> >(void)"
> > (??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
> > std::_Container_base::_Container_base(void)"
> > (__imp_??0_Container_base@std@@QAE@XZ) referenced in function
> > "protected: __thiscall std::_Vector_val<short,class
> > std::allocator<short> >::_Vector_val<short,class std::allocator<short>
> > >(class std::allocator<short>)"
> > (??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
> > 1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe : fatal
> > error LNK1120: 3 unresolved externals
> > These are my linker libs:
> > "C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
> > "C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
> > "C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
> > "C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
> > "C:\Program Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
> > I can't think of anything I'm missing.  Has no one come across this
> > symbol before???
> > thanks,
> > wes
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
