- To:
- Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
- Date: Fri, 2 May 2008 09:17:16 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=J9sic5O8CkToAEH4WTohqv7sZkJ1fLfrmN9HR4+U4yUK0imn4qn/Sx6Jn/Q6RGVISy82abXMLkyKAkNTQJUOAcAkpKebhvh1LEOF4S/t4pXUvaH+8/TVUC+w/9xlygLp/8fU1YX+jAkl9WyeaVmQvPxCBWU3AyPfFdj/Bq9CjhM=
This was my impression ... that CGAL relied only upon Boost template
header files which don't require compilation of the libs. Is this
correct?
wes
On Fri, May 2, 2008 at 9:15 AM, Andreas Fabri
wrote:
> Hi Wesley,
> I am not aware of a dependence of CGAL itself. Some demos use
> boost program_options to deal with input from the command line.
> andreas
> Wesley Smith wrote:
> > What libs from Boost are required to be compiled? I couldn't find
> > anything related to ContainerBase in the Boost libs. I don't want to
> > compile the entire thing since it's so massive. I guess what I'm
> > asking is what libs do you link against in your VC2008 projects?
> > thanks again,
> > wes
> > On Fri, May 2, 2008 at 6:26 AM, Ophir Setter
> wrote:
> > > Did you compile boost for vc 9.0? I got the _Container_base error using
> > > boost not compile in vc 9.0 and not because of CGAL. Anyway, I now run
> CGAL
> > > and boost on VC9 with no problems.
> > > On Fri, May 2, 2008 at 10:56 AM, Wesley Smith
> wrote:
> > > > Hi Ophir,
> > > > Many Thanks! I'll try this out and get back to the list. I had
> > > > though I had compiled CGAL with vc9, but I also have previous version
> > > > of vc on my system, so it's entirely possible that the build process
> > > > used on of those instead. Hopefully that's the case.
> > > > wes
> > > > On Fri, May 2, 2008 at 12:34 AM, Ophir Setter
> > > wrote:
> > > > > There is a need to compile all the libraries in vc 9.0
> > > > > I've done this already. Check out:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows/
> > > > > You'll be the beta user of this page and libraries.
> > > > > Don't forget to get vc 9.0 boost.
> > > > > I hope that this will solve your problems,
> > > > > Ophir
> > > > > On 5/1/08, Wesley Smith
> > > > > wrote:
> > > > > > Alright,
> > > > > > I'm still having massive issues with CGAL under VS2008. I tried
> > > > > compiling:
> > > > > > C:\Program Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
> > > > > > I get these errors:
> > > > > > 1>Linking...
> > > > > > 1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved
> > > > > > external symbol "__declspec(dllimport) public: void __thiscall
> > > > > > std::_Container_base::_Orphan_all(void)const "
> > > > > > (__imp_?_Orphan_all@_Container_base@std@@QBEXXZ)
> > > > > > referenced in
> > > > > > function "public: class std::vector<short,class
> std::allocator<short>
> > > > > > > & __thiscall std::vector<short,class std::allocator<short>
> > > > > > > ::operator=(class std::vector<short,class std::allocator<short>
> > > > > > const &)"
> (??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
> > > > > > external symbol "__declspec(dllimport) public: __thiscall
> > > > > > std::_Container_base::~_Container_base(void)"
> > > > > > (__imp_??1_Container_base@std@@QAE@XZ)
> > > > > > referenced in function
> "public:
> > > > > > __thiscall std::_Vector_val<short,class std::allocator<short>
> > > > > > > ::~_Vector_val<short,class std::allocator<short> >(void)"
> > > > > > (??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
> > > > > > std::_Container_base::_Container_base(void)"
> > > > > > (__imp_??0_Container_base@std@@QAE@XZ)
> > > > > > "protected: __thiscall std::_Vector_val<short,class
> > > > > > std::allocator<short> >::_Vector_val<short,class
> > > > > > > (class std::allocator<short>)"
> (??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
> > > > > > 1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe : fatal
> > > > > > error LNK1120: 3 unresolved externals
> > > > > > These are my linker libs:
> > > > > > "C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
> > > > > > "C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
> > > > > > "C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
> > > > > > "C:\Program
> Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
> > > > > > "C:\Program Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
> > > > > > I can't think of anything I'm missing. Has no one come across
> this
> > > > > > symbol before???
> > > > > > thanks,
> > > > > > wes
> > > > > > You are currently subscribed to cgal-discuss.
> > > > > > To unsubscribe or access the archives, go to
> > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/01/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ophir Setter, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Andreas Fabri, 05/02/2008
- RE: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Dave McVicar, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Fernando Cacciola, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/03/2008
