- To:
- Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
- Date: Fri, 2 May 2008 09:09:03 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=VMpD6En9T0YH8vcaMrhEVk9nPTKOZe6d0OHiAojyTintgqzzC/ImEB8zrP466sdV2OR7dGHEfnSTfUuQlV4+aywuwNy5fNwtLs0gCHPfkUnh0LCBW5Y2hn4N5NHi9M89pAf+Pd99ESO40eTOo7vllJBZBtrM4zXqXaMelh2tlcA=
What libs from Boost are required to be compiled? I couldn't find
anything related to ContainerBase in the Boost libs. I don't want to
compile the entire thing since it's so massive. I guess what I'm
asking is what libs do you link against in your VC2008 projects?
thanks again,
wes
On Fri, May 2, 2008 at 6:26 AM, Ophir Setter
wrote:
> Did you compile boost for vc 9.0? I got the _Container_base error using
> boost not compile in vc 9.0 and not because of CGAL. Anyway, I now run CGAL
> and boost on VC9 with no problems.
> On Fri, May 2, 2008 at 10:56 AM, Wesley Smith
> wrote:
> > Hi Ophir,
> > Many Thanks! I'll try this out and get back to the list. I had
> > though I had compiled CGAL with vc9, but I also have previous version
> > of vc on my system, so it's entirely possible that the build process
> > used on of those instead. Hopefully that's the case.
> > wes
> > On Fri, May 2, 2008 at 12:34 AM, Ophir Setter
> wrote:
> > > There is a need to compile all the libraries in vc 9.0
> > > I've done this already. Check out:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows/
> > > You'll be the beta user of this page and libraries.
> > > Don't forget to get vc 9.0 boost.
> > > I hope that this will solve your problems,
> > > Ophir
> > > On 5/1/08, Wesley Smith
> > > wrote:
> > > > Alright,
> > > > I'm still having massive issues with CGAL under VS2008. I tried
> > > compiling:
> > > > C:\Program Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
> > > > I get these errors:
> > > > 1>Linking...
> > > > 1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved
> > > > external symbol "__declspec(dllimport) public: void __thiscall
> > > > std::_Container_base::_Orphan_all(void)const "
> > > > (__imp_?_Orphan_all@_Container_base@std@@QBEXXZ)
> > > > referenced in
> > > > function "public: class std::vector<short,class std::allocator<short>
> > > > > & __thiscall std::vector<short,class std::allocator<short>
> > > > >::operator=(class std::vector<short,class std::allocator<short> >
> > > > const &)"
> > > > (??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
> > > > external symbol "__declspec(dllimport) public: __thiscall
> > > > std::_Container_base::~_Container_base(void)"
> > > > (__imp_??1_Container_base@std@@QAE@XZ)
> > > > referenced in function "public:
> > > > __thiscall std::_Vector_val<short,class std::allocator<short>
> > > > >::~_Vector_val<short,class std::allocator<short> >(void)"
> > > > (??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
> > > > std::_Container_base::_Container_base(void)"
> > > > (__imp_??0_Container_base@std@@QAE@XZ)
> > > > "protected: __thiscall std::_Vector_val<short,class
> > > > std::allocator<short> >::_Vector_val<short,class std::allocator<short>
> > > > >(class std::allocator<short>)"
> > > > (??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
> > > > 1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe : fatal
> > > > error LNK1120: 3 unresolved externals
> > > > These are my linker libs:
> > > > "C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
> > > > "C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
> > > > "C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
> > > > "C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
> > > > "C:\Program Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
> > > > I can't think of anything I'm missing. Has no one come across this
> > > > symbol before???
> > > > thanks,
> > > > wes
> > > > You are currently subscribed to cgal-discuss.
> > > > To unsubscribe or access the archives, go to
> > > > https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/01/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ophir Setter, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Andreas Fabri, 05/02/2008
- RE: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Dave McVicar, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Fernando Cacciola, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/03/2008
