cgal-discuss - Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
  • To:
  • Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
  • Date: Fri, 2 May 2008 09:56:08 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=wsduYbfeYiDQWt2m5DvDnW2z5qHCbQPRKY36Xato3MA2uJIeRb2WRm1UzxJS4L1fgW+W6SZM68JF2z9lKyAN9XU0W2tshlsbUWloHZKp4nUkQlOM0U7ru8b8Z7sN9095Sl6+HBqJYcKPOUkRTJ4e+ecEROVbjMKHl2pbRBZ4Grw=
Thanks for this data point. I am building DEBUG as well.
wes
On Fri, May 2, 2008 at 9:52 AM, Dave McVicar
wrote:
> I also get the same when I have the build configuration set to DEBUG,
> they go away when the build configuration is set to RELEASE. Perhaps a
> clue lies therein.
> -----Original Message-----
> From: Wesley Smith
> [mailto:]
> Sent: Friday, May 02, 2008 10:17 AM
> To:
> This was my impression ... that CGAL relied only upon Boost template
> header files which don't require compilation of the libs. Is this
> correct?
> wes
> On Fri, May 2, 2008 at 9:15 AM, Andreas Fabri
> wrote:
> > Hi Wesley,
> > I am not aware of a dependence of CGAL itself. Some demos use
> > boost program_options to deal with input from the command line.
> > andreas
> > Wesley Smith wrote:
> > > What libs from Boost are required to be compiled? I couldn't find
> > > anything related to ContainerBase in the Boost libs. I don't want
> to
> > > compile the entire thing since it's so massive. I guess what I'm
> > > asking is what libs do you link against in your VC2008 projects?
> > > thanks again,
> > > wes
> > > On Fri, May 2, 2008 at 6:26 AM, Ophir Setter
> > wrote:
> > > > Did you compile boost for vc 9.0? I got the _Container_base error
> using
> > > > boost not compile in vc 9.0 and not because of CGAL. Anyway, I now
> run
> > CGAL
> > > > and boost on VC9 with no problems.
> > > > On Fri, May 2, 2008 at 10:56 AM, Wesley Smith
> > wrote:
> > > > > Hi Ophir,
> > > > > Many Thanks! I'll try this out and get back to the list. I had
> > > > > though I had compiled CGAL with vc9, but I also have previous
> version
> > > > > of vc on my system, so it's entirely possible that the build
> process
> > > > > used on of those instead. Hopefully that's the case.
> > > > > wes
> > > > > On Fri, May 2, 2008 at 12:34 AM, Ophir Setter
> > > > wrote:
> > > > > > There is a need to compile all the libraries in vc 9.0
> > > > > > I've done this already. Check out:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs
> -on-windows/
> > > > > > You'll be the beta user of this page and libraries.
> > > > > > Don't forget to get vc 9.0 boost.
> > > > > > I hope that this will solve your problems,
> > > > > > Ophir
> > > > > > On 5/1/08, Wesley Smith
> wrote:
> > > > > > > Alright,
> > > > > > > I'm still having massive issues with CGAL under VS2008. I
> tried
> > > > > > compiling:
> > > > > > > C:\Program
> Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
> > > > > > > I get these errors:
> > > > > > > 1>Linking...
> > > > > > > 1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019:
> unresolved
> > > > > > > external symbol "__declspec(dllimport) public: void
> __thiscall
> > > > > > > std::_Container_base::_Orphan_all(void)const "
> (__imp_?_Orphan_all@_Container_base@std@@QBEXXZ)
> referenced
> in
> > > > > > > function "public: class std::vector<short,class
> > std::allocator<short>
> > > > > > > > & __thiscall std::vector<short,class std::allocator<short>
> > > > > > > > ::operator=(class std::vector<short,class
> > > > > > > const &)"
> (??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
> unresolved
> > > > > > > external symbol "__declspec(dllimport) public: __thiscall
> > > > > > > std::_Container_base::~_Container_base(void)"
> (__imp_??1_Container_base@std@@QAE@XZ)
> referenced in
> function
> > "public:
> > > > > > > __thiscall std::_Vector_val<short,class
> > > > > > > > ::~_Vector_val<short,class std::allocator<short> >(void)"
> (??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
> unresolved
> > > > > > > std::_Container_base::_Container_base(void)"
> (__imp_??0_Container_base@std@@QAE@XZ)
> referenced in
> function
> > > > > > > "protected: __thiscall std::_Vector_val<short,class
> > > > > > > std::allocator<short> >::_Vector_val<short,class
> > > > > > > > (class std::allocator<short>)"
> (??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
> > > > > > > 1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe :
> fatal
> > > > > > > error LNK1120: 3 unresolved externals
> > > > > > > These are my linker libs:
> > > > > > > "C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
> > > > > > > "C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
> > > > > > > "C:\Program
> Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
> > > > > > > "C:\Program
> > Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
> > > > > > > "C:\Program
> Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
> > > > > > > I can't think of anything I'm missing. Has no one come
> across
> > this
> > > > > > > symbol before???
> > > > > > > thanks,
> > > > > > > wes
> > > > > > > You are currently subscribed to cgal-discuss.
> > > > > > > To unsubscribe or access the archives, go to
> > > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss
