- To:
- Subject: Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase
- Date: Fri, 02 May 2008 18:15:21 +0200
Hi Wesley,
I am not aware of a dependence of CGAL itself. Some demos use
boost program_options to deal with input from the command line.
andreas
Wesley Smith wrote:
What libs from Boost are required to be compiled? I couldn't find
anything related to ContainerBase in the Boost libs. I don't want to
compile the entire thing since it's so massive. I guess what I'm
asking is what libs do you link against in your VC2008 projects?
thanks again,
wes
On Fri, May 2, 2008 at 6:26 AM, Ophir Setter
wrote:
Did you compile boost for vc 9.0? I got the _Container_base error using
boost not compile in vc 9.0 and not because of CGAL. Anyway, I now run CGAL
and boost on VC9 with no problems.
On Fri, May 2, 2008 at 10:56 AM, Wesley Smith
wrote:
Hi Ophir,wrote:
Many Thanks! I'll try this out and get back to the list. I had
though I had compiled CGAL with vc9, but I also have previous version
of vc on my system, so it's entirely possible that the build process
used on of those instead. Hopefully that's the case.
wes
On Fri, May 2, 2008 at 12:34 AM, Ophir Setter
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows/There is a need to compile all the libraries in vc 9.0
I've done this already. Check out:
You'll be the beta user of this page and libraries.--
Don't forget to get vc 9.0 boost.
I hope that this will solve your problems,
Ophir
On 5/1/08, Wesley Smith
wrote:
compiling:
Alright,
I'm still having massive issues with CGAL under VS2008. I tried
C:\Program Files\CGAL-3.3.1\examples\Triangulation_3\simple.cpp
I get these errors:
1>Linking...
1>cgal-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved
external symbol "__declspec(dllimport) public: void __thiscall
std::_Container_base::_Orphan_all(void)const "
(__imp_?_Orphan_all@_Container_base@std@@QBEXXZ)
referenced in
function "public: class std::vector<short,class std::allocator<short>
& __thiscall std::vector<short,class std::allocator<short>const &)"
::operator=(class std::vector<short,class std::allocator<short> >
(??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z)
external symbol "__declspec(dllimport) public: __thiscall
std::_Container_base::~_Container_base(void)"
(__imp_??1_Container_base@std@@QAE@XZ)
referenced in function "public:
__thiscall std::_Vector_val<short,class std::allocator<short>
::~_Vector_val<short,class std::allocator<short> >(void)"(??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ)
std::_Container_base::_Container_base(void)"
(__imp_??0_Container_base@std@@QAE@XZ)
"protected: __thiscall std::_Vector_val<short,class
std::allocator<short> >::_Vector_val<short,class std::allocator<short>
(class std::allocator<short>)"(??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z)
1>C:\luaAV\trunk\modules\space\windows\Debug\test_cgal.exe : fatal
error LNK1120: 3 unresolved externals
These are my linker libs:
"C:\Program Files\CGAL-3.3.1\lib\CGALcore++-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\lib\cgal-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\gmp-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\gmp\lib\mpfr-vc80-mt-gd.lib"
"C:\Program Files\CGAL-3.3.1\auxiliary\taucs\lib\liblapack.lib"
I can't think of anything I'm missing. Has no one come across this
symbol before???
thanks,
wes
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/01/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Ophir Setter, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Andreas Fabri, 05/02/2008
- RE: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Dave McVicar, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Fernando Cacciola, 05/02/2008
- Re: [cgal-discuss] Re: VS2008 link problems: ContainerBase, Wesley Smith, 05/03/2008
