- To:
- Subject: Re: [cgal-discuss] Is there a data structure for non-manifold 3D
- Date: Tue, 10 Jun 2008 07:37:47 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
Please stop reply to a message when you want to open a NEW discussion!!
On Tuesday 10 June 2008 03:35:18 Calvin Lim wrote:
> Hi all,
> I was searching thru the various data structure for 3D surfaces and the
> only one there is is the polyhedron class. However, within that class the
> connectivity of the nodes and faces are maintained properly, giving a 3D
> surface manifold (with or without boundaries).
> However, what if I have a dirty mesh which I obtained from somewhere
> which I want to use CGAL to perform cleaning up operations, but I will not
> be able to load it into the polyhedron class. By dirty mesh, I meant that
> it is possible for an edge to be adjacent to 3 or more faces.
> thanks all.
> Calvin
> _________________________________________________________________
> Easily edit your photos like a pro with Photo Gallery.
> http://get.live.com/photogallery/overview--
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- [cgal-discuss] What't the most efficient configuration for Bool Op of Nef_3, (continued)
- [cgal-discuss] What't the most efficient configuration for Bool Op of Nef_3, Max, 06/07/2008
- Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/09/2008
- [cgal-discuss] 3D surface Mesh Generation, Hui Ding, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Laurent Rineau, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Hui DING, 06/11/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/11/2008
- [cgal-discuss] format and viewer for the 3D surface Mesh Generation, Hui Ding, 06/12/2008
- [cgal-discuss] Is there a data structure for non-manifold 3D, Calvin Lim, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Laurent Rineau, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Marco Attene, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Max, 06/11/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Robert Bilant, 06/11/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
