- To: "" <>
- Subject: Re: [cgal-discuss] Is there a data structure for non-manifold 3D
- Date: Wed, 11 Jun 2008 10:27:53 +0800
- Organization: Max
hi Calvin,
CGAL::Nef_polyhedron_3 is capable of repesenting 2-manifold data structure
B/Rgds
Max
>> Hi all,
>> I was searching thru the various data structure for 3D surfaces and
>> the only one there is is the polyhedron class. However, within that
>> class the connectivity of the nodes and faces are maintained properly,
>> giving a 3D surface manifold (with or without boundaries).
>> However, what if I have a dirty mesh which I obtained from somewhere
>> which I want to use CGAL to perform cleaning up operations, but I will
>> not be able to load it into the polyhedron class. By dirty mesh, I
>> meant that it is possible for an edge to be adjacent to 3 or more faces.
>> thanks all.
>> Calvin
>> Enrich your blog with Windows Live Writer. Windows Live Writer
>> <http://get.live.com/writer/overview>
>Marco Attene
>Istituto di Matematica Applicata e Tecnologie Informatiche
>Consiglio Nazionale delle Ricerche
>Via de Marini 6 - 16149 - Genova - ITALY
>Tel. +39(0)106475691
>Fax. +39(0)106475660
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 3D surface Mesh Generation, (continued)
- [cgal-discuss] 3D surface Mesh Generation, Hui Ding, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Laurent Rineau, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Hui DING, 06/11/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/11/2008
- [cgal-discuss] format and viewer for the 3D surface Mesh Generation, Hui Ding, 06/12/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Laurent Rineau, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Marco Attene, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Max, 06/11/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
- Re: Re: [cgal-discuss] What's the most efficient configuration for, Max, 06/11/2008
