cgal-discuss - [cgal-discuss] Compile problem
  • To:
  • Subject: [cgal-discuss] Compile problem
  • Date: Fri, 19 Sep 2008 22:11:43 +0200 (CEST)
Hello all,
I'm having installing CGAL on the linux Cluster I run my simulation on.
The problem I'm having is that the install script does not recognize were I've
installed my boost file.
In the interactive interface I go in the Boost menu and setup both the INC and
DIR path correctly, but when I test the configuration I get the following
error:
Testing for BOOST ...
** Compilation failed **
** You will be shown a log now ... **
** Please press <ENTER> to continue. **
Compiler call:
icc -mp
-I/work/00981/pederzan/CGAL-3.3.1/include/CGAL/config/x86-64_Linux-2.6_icc-9.1
-I/work/00981/pederzan/boost/install/include/boost-1_36/boost/
-I/work/00981/pederzan/boost/install/include/boost-1_36/boost/ -c
'./tmp_test.cpp'
Got the following error messages:
./tmp_test.cpp(27): catastrophic error: could not open source file
"boost/version.hpp"
#include <boost/version.hpp>
compilation aborted for ./tmp_test.cpp (code 4)
What I did next is that I changed the include statement in test_BOOST.cpp
from #include <boost/version.hpp>
to #include
</work/00981/pederzan/boost/install/include/boost-1_36/boost/version.hpp>
At this point I no longer get the compilation error for temp_test.cpp, but for
tuple.hpp
I guess I could go and change the include statement in tuple.hpp as well, but
I
don't think this is the correct way to go.
Am I doing something wrong? What?
Thank you for your help
Jean-Noel Pederzani
