- To:
- Subject: Re: Re: [cgal-discuss] Compile problem
- Date: Fri, 19 Sep 2008 22:34:05 +0200 (CEST)
It does work without the work!!
now I'm getting a new error....
Linker call:
icc -o ./tmp_test ./tmp_test.o -L/work/00981/pederzan/boost/install/lib
-Wl,-R/work/00981/pederzan/boost/install/lib:/work/00981/pederzan/boost/install/lib
-lm
Got the following error messages:
./tmp_test.o: In function `main':
./tmp_test.cpp:(.text+0x4f): undefined reference to `std::cout'
./tmp_test.cpp:(.text+0xd8): undefined reference to `std::basic_ostream<char,
std::char_traits<char> >& std::operator<< <std::char_traits<char>
>(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
./tmp_test.cpp:(.text+0xe5): undefined reference to
`std::ostream::operator<<(int)'
./tmp_test.cpp:(.text+0xf2): undefined reference to `std::basic_ostream<char,
./tmp_test.cpp:(.text+0xff): undefined reference to
./tmp_test.cpp:(.text+0x10c): undefined reference to `std::basic_ostream<char,
./tmp_test.cpp:(.text+0x116): undefined reference to
./tmp_test.cpp:(.text+0x11e): undefined reference to `std::basic_ostream<char,
std::char_traits<char> >& std::endl<char, std::char_traits<char>
>(std::basic_ostream<char, std::char_traits<char> >&)'
./tmp_test.cpp:(.text+0x123): undefined reference to
`std::ostream::operator<<(std::ostream& (*)(std::ostream&))'
./tmp_test.o: In function `__sti__$E':
./tmp_test.cpp:(.text+0x139): undefined reference to
`std::ios_base::Init::Init()'
./tmp_test.cpp:(.text+0x13e): undefined reference to
`std::ios_base::Init::~Init()'
./tmp_test.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
Off to fix this one!
Jean-Noel
- [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Fernando Cacciola, 09/19/2008
- Re: Re: [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Joachim Reichel, 09/19/2008
- Re: [cgal-discuss] Compile problem, Sylvain Pion, 09/20/2008
