- To:
- Subject: Re: [cgal-discuss] Compile problem
- Date: Fri, 19 Sep 2008 22:26:09 +0200
Hi,
> Compiler call:
> icc -mp
> -I/work/00981/pederzan/CGAL-3.3.1/include/CGAL/config/x86-64_Linux-2.6_icc-9.1
> -I/work/00981/pederzan/boost/install/include/boost-1_36/boost/
> -I/work/00981/pederzan/boost/install/include/boost-1_36/boost/ -c
> './tmp_test.cpp'
> Got the following error messages:
> ./tmp_test.cpp(27): catastrophic error: could not open source file
> "boost/version.hpp"
> #include <boost/version.hpp>
> compilation aborted for ./tmp_test.cpp (code 4)
> What I did next is that I changed the include statement in test_BOOST.cpp
> from #include <boost/version.hpp>
> to #include
> </work/00981/pederzan/boost/install/include/boost-1_36/boost/version.hpp>
the "/boost" part at the end of the include directory is wrong. It should work
without that part.
Joachim
- [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Fernando Cacciola, 09/19/2008
- Re: Re: [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Joachim Reichel, 09/19/2008
- Re: [cgal-discuss] Compile problem, Sylvain Pion, 09/20/2008
