- To:
- Subject: Re: [cgal-discuss] Compile problem
- Date: Fri, 19 Sep 2008 17:17:01 -0300
Hello Jean-Noel,
> Hello all,
> I'm having installing CGAL on the linux Cluster I run my simulation
> on. The problem I'm having is that the install script does not
> recognize were I've installed my boost file.
> In the interactive interface I go in the Boost menu and setup both the > INC and
It is this the path you entered?
/work/00981/pederzan/boost/install/include/boost-1_36/
that is, without the trailing /boost?
HTH
Fernando Cacciola
GeometryFactory
- [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Fernando Cacciola, 09/19/2008
- Re: Re: [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Joachim Reichel, 09/19/2008
- Re: [cgal-discuss] Compile problem, Sylvain Pion, 09/20/2008
