- To:
- Subject: Re: [cgal-discuss] Compile problem
- Date: Fri, 19 Sep 2008 22:41:23 +0200
Hi,
> Linker call:
> icc -o ./tmp_test ./tmp_test.o
> -L/work/00981/pederzan/boost/install/lib
> -Wl,-R/work/00981/pederzan/boost/install/lib:/work/00981/pederzan/boost/install/lib
> -lm
> Got the following error messages:
> ./tmp_test.o: In function `main':
> ./tmp_test.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
it seems that you're using icc to link with something compiled with g++. Most
probably this is not going to work.
Note that icc 9.0 is supported under Windows only, not Linux.
Joachim
- [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Fernando Cacciola, 09/19/2008
- Re: Re: [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Joachim Reichel, 09/19/2008
- Re: [cgal-discuss] Compile problem, Sylvain Pion, 09/20/2008
