- To:
- Subject: Re: Re: [cgal-discuss] Compile problem
- Date: Fri, 19 Sep 2008 22:50:27 +0200 (CEST)
I added -lstdc++ to the icc flags and that solved that issue
now I get (as usual) another error
** Compiling CGAL 3.3.1 **
OS: x86-64_Linux-2.6
COMPILER: Intel 9.1
BOOST: supported (1.36.0)
BOOST_PROGRAM_OPTIONS: not supported
BOOST_BIMAP: not supported
X11: supported (11.0)
GMP: not supported
GMPXX: not supported
MPFR: not supported
ZLIB: supported (1.2.1.2)
BLAS: not supported
LAPACK: not supported
ATLAS: not supported
LEDA: not supported
LEDAWIN: not supported
OPENGL: supported (1.5)
QT: not supported
TAUCS: not supported
Generating Makefiles ... done.
Building libCGAL static ...
Compilation of libCGAL static failed.
You will be shown a log now ...
** Please press <ENTER> to continue. **
icc -O2 -mp
'-I/work/00981/pederzan/CGAL-3.3.1/include/CGAL/config/x86-64_Linux-2.6_icc-9.1'
'-I/work/00981/pederzan/CGAL-3.3.1/include'
-I/work/00981/pederzan/boost/install/include/boost-1_36/ -I/usr/X11R6/include
-c assertions.cpp
icc -O2 -mp
-c Bbox_2_intersections.cpp
/work/00981/pederzan/CGAL-3.3.1/include/CGAL/Point_2.h(80): error: expected an
identifier
(const T1 &x, const T2 &y)
/work/00981/pederzan/CGAL-3.3.1/include/CGAL/Point_2.h(76): error: not a valid
member class or function template declaration
Self
Any idea what causes this?
Thanks
Jean-Noel
- [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Fernando Cacciola, 09/19/2008
- Re: Re: [cgal-discuss] Compile problem, pederzani, 09/19/2008
- Re: [cgal-discuss] Compile problem, Joachim Reichel, 09/19/2008
- Re: [cgal-discuss] Compile problem, Sylvain Pion, 09/20/2008
