- To:
- Subject: Re: [cgal-discuss] Vertex_handle
- Date: Tue, 7 Oct 2008 21:00:36 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=wjMWamQKPrUAOs99Qq+zBi/Mo0CZCq1WhWtx50yIZUUTrkuyxw37E8+LukFuHBl6fG CIv39i/UuZDKatahSsoSbJK13dN0y8z9c53bKlVIQJwj6XUVvkO0HSZYwR0RXPxRnAv+ RO9C1+iWLH3Dsw7uNDrrBexNVTd/t5/ZQQmDI=
Thanks a lot!
Extremely useful!
JPi
On Tue, Oct 7, 2008 at 8:52 PM, Andreas Fabri
wrote:
> Dennis Endt wrote:
>> Andreas Fabri schrieb:
>>> Dennis Endt wrote:
>>>> Hi,
>>>> thats my Problem:
>>>> /typedef CGAL::Simple_cartesian<double> SK;
>>>> typedef CGAL::Filtered_kernel<SK> FK;
>>>> struct K : public FK {};
>>>> typedef K::Point_3 dPoint;
>>>> typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
>>>> typedef Triangulation::Vertex_handle Vertex_handle;
>>>> Triangulation T;
>>>> list<Vertex_handle> vertices; // vector to hold the points of the convex
>>>> hull
>>>> T.incident_vertices(T.infinite_vertex(), back_inserter(vertices)); //
>>>> get the points from Delaunay/
>>>> Can anyone plz tell how I get access to the points corresponding to the
>>>> vertex_handles? It is very urgent.
>>>> I tried everything so far...it cannot be so difficult ;)
>>>> Best Dennis
>>> for(list<Vertex_handle>::iterator it = vertices.begin();
>>> it != vertices.end();
>>> ++it){
>>> std::cout (*it)->point() << std::endl;
>> Thanks a lot! :)
>> I only forgot to set the brackets. It can be so easy :)
>> Best
>> Dennis
> And here comes the "official" link
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Handle_ref/Concept_Handle.html
> andreas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
JuanPi
"You can know the name of a bird in all the languages of the world,
but when you're finished, you'll know absolutely nothing whatever
about the bird... So let's look at the bird and see what it's doing --
that's what counts. I learned very early the difference between
knowing the name of something and knowing something."
Richard Feynman - What Do You Care What Other People Think
- [cgal-discuss] How to install supported library for CGAL???, Samay Kumar, 10/07/2008
- Re: [cgal-discuss] How to install supported library for CGAL???, Roger House, 10/07/2008
- [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Manuel Caroli, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/07/2008
- Message not available
- [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/08/2008
- [cgal-discuss] Redudant Points, Dennis Endt, 10/08/2008
- Re: [cgal-discuss] Vertex_handle, Monique Teillaud, 10/09/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] How to install supported library for CGAL???, Samay Kumar, 10/08/2008
