- To:
- Subject: [cgal-discuss] Redudant Points
- Date: Wed, 08 Oct 2008 13:16:08 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=EFLGm9FpeP6e3hOr+nyW8cw24gARzaRDFjASPTZyjtacSYgjn6BAwfxFwbX2bTY3mD EUCsk2g+gBkKv6aAhLsov11gLFsVGT/r7rtOOb1sALSFj2fLAZmK1CBR2ULcfuOmSADL BjBhcFd7UclItb7fqUmkhZ0rndL8jy9+QOqgQ=
Hi,
I`ve a question if a Functionality in CGAL exists that I need.
*The problem:*
As I described so far I worked with geodata and faces, described as
walls, roofs, ground surfaces.
So now I would like to remove redudant points:
In the first step I compute the convex hull of every face. So now I have
the boundary points of the face.
In the next step I would like to remove the points, which are
approxiamatly ordered along a line between two other points.
The problem is the points are not collinear and in 3D.
How can I solve this problem?
Best
Dennis
- Re: [cgal-discuss] How to install supported library for CGAL???, (continued)
- Re: [cgal-discuss] How to install supported library for CGAL???, Roger House, 10/07/2008
- [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Manuel Caroli, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/07/2008
- Message not available
- [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Dennis Endt, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Juan Pablo Carbajal, 10/07/2008
- Re: [cgal-discuss] Vertex_handle, Andreas Fabri, 10/08/2008
- [cgal-discuss] Redudant Points, Dennis Endt, 10/08/2008
- Re: [cgal-discuss] Vertex_handle, Monique Teillaud, 10/09/2008
