cgal-discuss - Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • To:
  • Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • Date: Sun, 02 Nov 2008 15:52:30 +0100
Hi Dennis,
I don't actually understand what is wrong about that. The triangulation in your picture looks quite ok to me.
Also e.g. in your finite_edge_iterator loop you only get finite edges, so if your triangulation contains only 4 points it is a tetrahedron which consists of 6 edges.
best
Manuel
Dennis Endt wrote:
Here is a Screenshot of that waht CGAL returns.
And here are the points to that fassade:
2585709.716 5703009.266 3.0
2585710.5465 5703008.192 8.0
2585711.377 5703007.118 3.0
2585711.377 5703007.118 0.0
2585709.716 5703009.266 0.0
That not the only case where CGAL returns a wrong number of edges or facets.
What have I to do to get a clean triangulation?
Best,
Dennis
Dennis Endt schrieb:
Hi,
I`ve a problem with the 3D Delaunay Triangulation. I want to triangulate
buildings with multiple fassades. Ech fassade contains of a certain
number of vertices.
That`s my code:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
typedef CGAL::Simple_cartesian<double> SK;
typedef CGAL::Filtered_kernel<SK> FK;
struct K : public FK {};
typedef K::Point_3 Point_3;
typedef K::Triangle_3 Triangle_3;
typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
Triangulation T..... // the Triangulation object of my current fassade
for(Triangulation::Finite_edges_iterator ie = T.finite_edges_begin(); ie
!= T.finite_edges_end(); ie++)
// The problem is, that the number of infinite_edges is too high.
For example the number of vertices is 5, he gives me 9 edges or 4 and he
gives me 6 edges.
Why does he gives me so a large number of edges? I would expect 7 or 5
so far. What can I do, about to get a clean and good triangulation of
each of my fassades?
Best,
Dennis
