cgal-discuss - Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • To:
  • Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • Date: Mon, 3 Nov 2008 09:27:54 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=uWvbTsXS8F3rLmPfAV/B2HJc+0pohtzbPIZm4IXoOICtXWZqO6LCLopLeUNs58AUli bMic5WFVBnDylzTRSYNtRVbVQVrLQvRxnAl/dhzxPo26yAuAUXLXM8shGXMoOyt2jigY z5Gv11ap4sjgvBGzPJHkJgeU34vvYDvwyt64s=
Ah, sorry. You had answered the question I thought he asked several
times on the mailing list already, so I thought to take over for once
:) But I misread the mail.
Sorry for the confusion.
Nico
On Mon, Nov 3, 2008 at 8:59 AM, Monique Teillaud
wrote:
> Nico Kruithof wrote:
>> It is a pair of a cell_handle and an int:
>> Cell_handle ch = it->first;
>> int i = it->second;
>> The facet is one of the faces of the Cell_handle (tetrahedron). More
>> specifically, it doesn't contain the vertex with index i. So the
>> Cell_handle contains four vertices and each vertex is associated with
>> a point:
>> ch->vertex(0)->point()
>> ch->vertex(1)->point()
>> ch->vertex(2)->point()
>> ch->vertex(3)->point()
>> and the face contains the points:
>> ch->vertex((i+1)%4)->point()
>> ch->vertex((i+2)%4)->point()
>> ch->vertex((i+3)%4)->point()
>> Hope this makes things clear.
> not really, I am afraid... Nico, you missed a few chapters of the novel:
> Dennis is now using a 2d triangulation.
>> On Sun, Nov 2, 2008 at 10:51 PM, Dennis Endt
>> wrote:
>>> Monique Teillaud schrieb:
>>>> If you are lucky (= your points really don't belong to a plane
>>>> parallel to any xy,xz,yz plane), you will get the same triangulation
>>>> three times, which is not what you want (I guess so). Yhen using one
>>>> of these random traits should give you what you want.
>>>> If you are less lucky, one of the computationa will crash. Then, use
>>>> one of the other two.
>>>> I'm afraid that's the best you can do if you don't know anything about
>>>> your data, except the fact that they are almost coplanar.
>>> Hi Monique,
>>> how can avoid a crash? Is it enough to check for "is_valid()"?
>>> I read the manual and solved the problem with the edges and the points.
>>> But I don`t understand how I get the 3 Points of a face with the help
>>> of the following loop?
>>> for(Delaunay::Finite_faces_iterator it = T.finite_faces_begin(); it !=
>>> T.finite_faces_end(); it++)
>>> I thought about:
>>> (*it).vertex(1)->point()
>>> (*it).vertex(2)->point()
>>> (*it).vertex(3)->point()
>>> Is that right?
>>> Best,
>>> Dennis
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
