cgal-discuss - Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • To:
  • Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
  • Date: Sun, 2 Nov 2008 23:56:25 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=mssOa0sbqhtVaItsbvHknjJLCvb8p132lcQnUF2oj5LrmyzePD3/VaWL1uaU6a5MWS UD9kaLl9ljV+26Zy2+f7M1KJOiHGQeKynoXqS9zW7HvPl2dsbd2Q/FNZOJcVxqtALl1g 5iMJP8jdYl919qlZJh4jKUdftpKZkZ/ZowSu0=
It is a pair of a cell_handle and an int:
Cell_handle ch = it->first;
int i = it->second;
The facet is one of the faces of the Cell_handle (tetrahedron). More
specifically, it doesn't contain the vertex with index i. So the
Cell_handle contains four vertices and each vertex is associated with
a point:
ch->vertex(0)->point()
ch->vertex(1)->point()
ch->vertex(2)->point()
ch->vertex(3)->point()
and the face contains the points:
ch->vertex((i+1)%4)->point()
ch->vertex((i+2)%4)->point()
ch->vertex((i+3)%4)->point()
Hope this makes things clear.
Bests,
Nico
On Sun, Nov 2, 2008 at 10:51 PM, Dennis Endt
wrote:
> Monique Teillaud schrieb:
>> If you are lucky (= your points really don't belong to a plane
>> parallel to any xy,xz,yz plane), you will get the same triangulation
>> three times, which is not what you want (I guess so). Yhen using one
>> of these random traits should give you what you want.
>> If you are less lucky, one of the computationa will crash. Then, use
>> one of the other two.
>> I'm afraid that's the best you can do if you don't know anything about
>> your data, except the fact that they are almost coplanar.
> Hi Monique,
> how can avoid a crash? Is it enough to check for "is_valid()"?
> I read the manual and solved the problem with the edges and the points.
> But I don`t understand how I get the 3 Points of a face with the help
> of the following loop?
> for(Delaunay::Finite_faces_iterator it = T.finite_faces_begin(); it !=
> T.finite_faces_end(); it++)
> I thought about:
> (*it).vertex(1)->point()
> (*it).vertex(2)->point()
> (*it).vertex(3)->point()
> Is that right?
> Best,
> Dennis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
