- To:
- Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
- Date: Sun, 02 Nov 2008 16:52:48 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=RFZitigruOhxFKEdQUzoVbOoJL1I9ajlnFf4bievL1UbWzAe+ij1NhSajGjLH2OML2 cY54b/M4L0+MJOcefFQOPnoHK5yhQVrODC2ltjcU53HGs+PokP0TTolDqe1MIXc/QNbU EfYmF14rbdYvJU05QqlSPAKuHHyzvzSLatOrA=
Hi Monique,
yes I have had a look.
But it seemed to work with the 3d Delaunay Triangulation and so it
didn`t matter.
But now I found this situation.
So plz tell me if I`m wrong:
Because I don`t know which wall is a vertical or a horizontal wall and
so on I would use:
CGAL::Triangulation_euclidean_traits_xy_3<K>
CGAL::Triangulation_euclidean_traits_xz_3<K>
and CGAL::Triangulation_euclidean_traits_yz_3<K>
for every of my fassades and then merge the results of all of them?
Could this work? Or is there a more simple way to do this?
Two other questions:
How do I get the points of an edge of a 2d Delaunay Triangulation:
for(Delaunay::Finite_edges_iterator ie = T.finite_edges_begin(); ie !=
T.finite_edges_end(); ie++)
ie->first->vertex(ie->second)->point() // doesn`t work so far
ie->first->vertex(ie->third)->point()
What`s wrong on this:
for(Delaunay::Finite_faces_iterator it = T.finite_faces_begin(); it !=
T.finite_faces_end(); it++)
Triangle_3 delaunayTriangle = T.triangle(*it); // error
- [cgal-discuss] Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Manuel Caroli, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Olivier Devillers, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Andreas Fabri, 11/03/2008
