- To:
- Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
- Date: Mon, 03 Nov 2008 08:59:04 +0100
Nico Kruithof wrote:
It is a pair of a cell_handle and an int:
Cell_handle ch = it->first;
int i = it->second;
The facet is one of the faces of the Cell_handle (tetrahedron). More
specifically, it doesn't contain the vertex with index i. So the
Cell_handle contains four vertices and each vertex is associated with
a point:
ch->vertex(0)->point()
ch->vertex(1)->point()
ch->vertex(2)->point()
ch->vertex(3)->point()
and the face contains the points:
ch->vertex((i+1)%4)->point()
ch->vertex((i+2)%4)->point()
ch->vertex((i+3)%4)->point()
Hope this makes things clear.
not really, I am afraid... Nico, you missed a few chapters of the novel: Dennis is now using a 2d triangulation.
On Sun, Nov 2, 2008 at 10:51 PM, Dennis Endt
wrote:
Monique Teillaud schrieb:
If you are lucky (= your points really don't belong to a planeHi Monique,
parallel to any xy,xz,yz plane), you will get the same triangulation
three times, which is not what you want (I guess so). Yhen using one
of these random traits should give you what you want.
If you are less lucky, one of the computationa will crash. Then, use
one of the other two.
I'm afraid that's the best you can do if you don't know anything about
your data, except the fact that they are almost coplanar.
how can avoid a crash? Is it enough to check for "is_valid()"?
I read the manual and solved the problem with the edges and the points.
But I don`t understand how I get the 3 Points of a face with the help
of the following loop?
for(Delaunay::Finite_faces_iterator it = T.finite_faces_begin(); it !=
T.finite_faces_end(); it++)
I thought about:
(*it).vertex(1)->point()
(*it).vertex(2)->point()
(*it).vertex(3)->point()
Is that right?
Best,
Dennis
- [cgal-discuss] Re: Delaunay Triangulation - number of edges, (continued)
- [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Manuel Caroli, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Olivier Devillers, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Andreas Fabri, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Bernd Gaertner, 11/03/2008
