- To:
- Subject: Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is
- Date: Sun, 30 Nov 2008 21:11:17 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=q7cilKRNp2Dn2SidiTJEZQ4A3vaRCAYJLHxQcfH/MjaDf8oLvmfqUyFjGWOVGei3p4 HyEiyOgILxFCm85SXXNvlCv4HdQo6+jbHG2DGnyq8yZ+Vbr8N2t+9T84WZf6TGZt2kSv kybWaNAezpfVzsyBrGwB9Rr/Hmo+33trtw67k=
The subdivision is done in the Skin_surface_sqrt3 class
(subdivide_skin_surface_mesh_3.h). The policy.to_surface(v) moves the
vertex onto the surface. The rest of the code is manipulation of the
halfedge data structure to the subdivided surface.
Good luck.
Nico
On Sun, Nov 23, 2008 at 11:06 AM, Nico Kruithof
wrote:
> The subdivision is either bisecting edges or trisecting edges and then
> retriangulating in 4 or 9 triangles. I'll give you a pointer to the
> code that does the trick later this week.
> Bests,
> Nico
> On Fri, Nov 21, 2008 at 10:41 AM, Benjamin schwarz
> wrote:
>>> You should thank Joachim Reichel for the Debian package, not me.
>> Oups... thank you for corecting me Sylvain, and thank you to Joachim
>> for the debian package.
>> Another question I forgot to ask concerning the skin package : what
>> subdivision scheme is currently implemented ? According to the mesh it
>> seems to be "sqrt3", am I correct ? Is it possible to use "Chew" ?
>>> ( and I am clueless about the skin surface package as well :-) )
>>> Sylvain Pion
>>> INRIA Sophia-Antipolis
>>> Geometrica Project-Team
>>> CGAL, http://cgal.org/
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Sylvain Pion, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Nico Kruithof, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Nico Kruithof, 11/30/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Laurent Rineau, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Nico Kruithof, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Nico Kruithof, 11/30/2008
