- To: <>
- Subject: RE: [cgal-discuss]
- Date: Tue, 20 Jan 2009 18:26:02 +0800
- Importance: Normal
Thanks I have used typedef CGAL::Exact_predicates_inexact_constructions_kernel K1 before. However, it takes nearly 1 hour to insert about 300000 points. Therefore, I have switched from Exact_predicates_inexact_constructions_kernel to Cartesian. And except by using exact predicate, may I ask if it still exist some other ways to prevent the stack overflow in version 3.3.1 of CGAL? Thank you > Date: Tue, 20 Jan 2009 11:16:04 +0100 > From: > To: > Subject: Re: [cgal-discuss] > > Kwok Jasper wrote: > > Excuse me, may I ask something about 3D Delaunay triangulation in CGAL? > > > > I have tried to use the following types. > > > > typedef CGAL::Cartesian<double> K1; > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation; > > typedef Triangulation::Point Point_tr; > > > > > > when I insert about 300000 points into the triangulation, > > I got a stack overflow problem. > > > > May I ask what may be the possible reason for the stack overflow to occur? > > > > > > ------------------------------------------------------------------------ > > With Cartesian<double> anything can go on. In order to avoid > floiting point arithmetic related problems you should use the > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > andreas > > > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss 想同MSN Buddy傾計了解佢多d? 參觀MSN Buddy部屋啦! |
- [cgal-discuss], Kwok Jasper, 01/01/2009
- Re: [cgal-discuss], Monique Teillaud, 01/01/2009
- <Possible follow-up(s)>
- [cgal-discuss], Kwok Jasper, 01/03/2009
- Re: [cgal-discuss], Shuchu, 01/14/2009
- [cgal-discuss], Kwok Jasper, 01/08/2009
- RE: [cgal-discuss], Kwok Jasper, 01/08/2009
- [cgal-discuss], Kwok Jasper, 01/20/2009
- Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 01/20/2009
- RE: [cgal-discuss], Kwok Jasper, 01/20/2009
- Re: [cgal-discuss], Andreas Fabri, 01/20/2009
- Re: [cgal-discuss], Sylvain Pion, 01/20/2009
- RE: [cgal-discuss], Kwok Jasper, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/20/2009
- [cgal-discuss], soufiane.khiat, 01/20/2009
- Re: [cgal-discuss], Andreas Fabri, 01/21/2009
- Re: [cgal-discuss], skhiat, 01/22/2009
- [cgal-discuss], Kwok Jasper, 01/22/2009
- Re: [cgal-discuss], Andreas Fabri, 01/22/2009
