- To:
- Subject: Re: [cgal-discuss]
- Date: Thu, 22 Jan 2009 13:36:32 +0100
Selon Andreas Fabri
> wrote:
> > Hello I am a student at the university of Poitiers in Science and
> Mathematics
> > and plans to specialize in 3D visualization. Poitiers has a laboratory
> whose
> > work is quite interesting (http://www.sic.sp2mi.univ-poitiers.fr/). Under
> > a
> > draft person I need to create a parser "3D L-System" with operations based
> on
> > 2D and 3D objects the aim is to come to something equivalent to
> > http://blip
> > .tv/file/1473837 (city of engine) so CGAL choice seemed natural. But
> despite my
> > careful reading of the documentation that could not answer my questions.
> That
> > is why I ask :
> > * Is what makes CGAL operations such extrusions?
> Hi Soufiane,
> CGAL does not offer extrusion.
> > * Does CGAL allows for Polyhedrons and especially for Nef_Polyhedrons
> recover
> > vertex and triangle indices for is to make a exporteur in any format and
> can
> > display it in geomviewer other thing?
> Nef_polyhedrons can be converted to Polyhedron, unless they have lower
> dimensional faces, or edges with more than two adjacent faces. For the
> latter
> we have output routines for the off format.
> > * Does CGAL can add vertex and triangle indices (model in a modeler any)
> > in
> a
> > Polyhedron and especially a Nef_Polyhedrons to create it and apply Boolean
> > operators?
> Adding indices should be possible as you can provide your own vertex,
> halfedge
> and face class. However, you have to traverse the vertices yourself in order
> to affect integers 0,..,n-1
> A maybe simpler alternative is to use a std::map<Vertex_handle, unsigned
> int>
> best regards,
> andreas
> > Thank you in advance for your future answers.
> > Sincerely KHIAT Soufiane
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Thank for you answers
- RE: [cgal-discuss], (continued)
- RE: [cgal-discuss], Kwok Jasper, 01/20/2009
- Re: [cgal-discuss], Andreas Fabri, 01/20/2009
- Re: [cgal-discuss], Sylvain Pion, 01/20/2009
- RE: [cgal-discuss], Kwok Jasper, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/20/2009
- [cgal-discuss], soufiane.khiat, 01/20/2009
- Re: [cgal-discuss], Andreas Fabri, 01/21/2009
- Re: [cgal-discuss], skhiat, 01/22/2009
- [cgal-discuss], Kwok Jasper, 01/22/2009
- Re: [cgal-discuss], Andreas Fabri, 01/22/2009
- [cgal-discuss] about the function incident_vertices() and output iterator, Kwok Jasper, 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output, Andreas Fabri, 01/22/2009
- RE: [cgal-discuss] about the function incident_vertices() and output, Kwok Jasper, 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output, Laurent Rineau (GeometryFactory), 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output iterator, Laurent Rineau (GeometryFactory), 01/22/2009
- RE: [cgal-discuss] about the function incident_vertices() and, Kwok Jasper, 01/22/2009
