cgal-discuss - Re: [cgal-discuss]
Re: [cgal-discuss]
  • To:
  • Subject: Re: [cgal-discuss]
  • Date: Tue, 20 Jan 2009 11:33:03 +0100
typedef CGAL::Exact_predicates_inexact_constructions_kernel K1
before.
However, it takes nearly 1 hour to insert about 300000 points.
Considering your (extremely slow) timing, I imagine that your points are not at all in general position, but in a very degenerate one. Could it be, for example, that all your points lie on a sphere? That would explain the slow computation.
Furthermore, the stack overflow in CGAL 3.3 would then come from (you or CGAL) calling incident_vertices() on the infinite vertex, which has too many neighbors (all the points).
This issue of stack overflow has been solved in CGAL-3.4, as Laurent said.
However, your slowness issue has nothing to do with this. You should tell us more about your input data.
Camille
