cgal-discuss - Re: [cgal-discuss]
Re: [cgal-discuss]
  • To:
  • Subject: Re: [cgal-discuss]
  • Date: Tue, 20 Jan 2009 11:30:21 +0100
  • Organization: INRIA
Kwok Jasper wrote:
> Thanks
> I have used
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K1
> before.
> However, it takes nearly 1 hour to insert about 300000 points.
> Therefore, I have switched from
> Exact_predicates_inexact_constructions_kernel to Cartesian.
> And except by using exact predicate,
> may I ask if it still exist some other ways to prevent the stack
> overflow in version 3.3.1 of CGAL?
I don't think so.
What is special about your data set that it triggers this stack overflow?
Is it a lot of points on a sphere, or something like that?
I would be glad to get access to it to see what going wrong and if we can
do something about it.
> Thank you
> > Date: Tue, 20 Jan 2009 11:16:04 +0100
> > From:
> > To:
> > Kwok Jasper wrote:
> > > Excuse me, may I ask something about 3D Delaunay triangulation in CGAL?
> > > I have tried to use the following types.
> > > typedef CGAL::Cartesian<double> K1;
> > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation;
> > > typedef Triangulation: :Point Point_tr;
> > > when I insert about 300000 points into the triangulation,
> > > I got a stack overflow problem.
> > > May I ask what may be the possible reason for the stack overflow to
> occur?
> > With Cartesian<double> anything can go on. In order to avoid
> > floiting point arithmetic related problems you should use the
> > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1;
> > andreas
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
> 想同MSN Buddy傾計了解佢多d? 參觀MSN Buddy部屋啦!
> <http://buddy.hk.msn.com/>
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
