- To: <>
- Subject: [cgal-discuss] about the function incident_vertices() and output iterator
- Date: Thu, 22 Jan 2009 22:30:21 +0800
- Importance: Normal
Thank you very much and for the following for calling the incident_vertices function > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation; > > typedef Triangulation::Point Point_tr; > > > > Triangulation Tr; > > > > Vertex_handle v = Tr.insert(Point_tr(0,0,0)); > > Tr.insert(Point_tr(40,20,10)); > > //...insert some more points > > > > vector<Vertex_handle> con; > > con.resize(800); > > > > vector <Vertex_handle>::iterator start_inci = con.begin(); > > vector<Vertex_handle>::iterator end_inci = con.end(); > > vector<Vertex_handle>::iterator curr_inci; > > > > for(curr_inci = start_inci; curr_inci != end_inci; ++curr_inci) > > { > > //do sth with the vertex handles. > > } may I ask if it is a proper way to use it. In the method , I use con.resize(800); If I didn't use the resize() function there. then it have a exception telling that the iterator cannot be deferenced May I ask if the above code is a proper way to use the incident_vertices() function ? Thank you > Date: Thu, 22 Jan 2009 15:23:24 +0100 > From: > To: > Subject: Re: [cgal-discuss] > > Kwok Jasper wrote: > > Excuse me, may I ask something? > > > > I have tried the code below > > and I am not sure if I have used the function incident_vertices correctly. > > May I ask if anyone is willing to tell me whether I have used that > > function properly? > > > > > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation; > > typedef Triangulation::Point Point_tr; > > > > Triangulation Tr; > > > > Vertex_handle v = Tr.insert(Point_tr(0,0,0)); > > Tr.insert(Point_tr(40,20,10)); > > //...insert some more points > > > > vector<Vertex_handle> con; > > con.resize(800); > > > > vector <Vertex_handle>::iterator start_inci = con.begin(); > > vector<Vertex_handle>::iterator end_inci = con.end(); > > vector<Vertex_handle>::iterator curr_inci; > > > > for(curr_inci = start_inci; curr_inci != end_inci; ++curr_inci) > > { > > //do sth with the vertex handles. > > } > > > > > > And may I ask one more thing? > > If there is a Vertex_handle v, then is it possible to get the x, y > > coordinate of the vertex represented by v? > > I have looked at the manual of 2D and 3D triangulation and cannot find > > any examples about it. > > May I ask if there is some method for doing that? > > > > Thank you very much for your attention. > > Once you have found the reference manual page for Vertex, things will > become obvious. > > On this page > http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html > > scroll down to the end, and click on > > TriangulationDataStructure_2::Face > TriangulationDataStructure_2::Vertex > > to see what you can do with a vertex. > > andreas > > > > > > > > > > > > ------------------------------------------------------------------------ > > 利用 Windows Live™ Photos 輕?分享相片。 簡易上載及分享照片 > > <http://www.microsoft.com/windows/windowslive/events.aspx> > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss 想同MSN Buddy傾計了解?多d? 參觀MSN Buddy部屋?! |
- Re: [cgal-discuss], (continued)
- Re: [cgal-discuss], Sylvain Pion, 01/20/2009
- RE: [cgal-discuss], Kwok Jasper, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/21/2009
- Re: [cgal-discuss], Camille Wormser, 01/20/2009
- [cgal-discuss], soufiane.khiat, 01/20/2009
- Re: [cgal-discuss], Andreas Fabri, 01/21/2009
- Re: [cgal-discuss], skhiat, 01/22/2009
- [cgal-discuss], Kwok Jasper, 01/22/2009
- Re: [cgal-discuss], Andreas Fabri, 01/22/2009
- [cgal-discuss] about the function incident_vertices() and output iterator, Kwok Jasper, 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output, Andreas Fabri, 01/22/2009
- RE: [cgal-discuss] about the function incident_vertices() and output, Kwok Jasper, 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output, Laurent Rineau (GeometryFactory), 01/22/2009
- Re: [cgal-discuss] about the function incident_vertices() and output iterator, Laurent Rineau (GeometryFactory), 01/22/2009
- RE: [cgal-discuss] about the function incident_vertices() and, Kwok Jasper, 01/22/2009
