- To: <>
- Subject: [cgal-discuss] advice about CGAL Delaunay Triangulation
- Date: Mon, 2 Feb 2009 21:56:33 +0800
- Importance: Normal
Excuse me, may I seek for some advise about using the Delaunay Triangulation? If I have the Delaunay Triangulation declared as follows typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; After I have inserted several ten thousand points into the triangulation, I use the Finite_facets_iterator to iterate over all of the triangular faces in the triangulation. For each of the triangular face, I check for some condition and if they satify the condition, I push then into a std::list<Finite_facets_iterator> However, when I use the std::list<Finite_facets_iterator> to store all those triangular face, I get the exception saying that memory for the program is used up. May I ask if it is that for huge number of points inserted into the Delaunay Triangulation, it is not recommended to use std::list or std::vector to store the above information? If it is not recommended, what structure may I use for the storage. Thank you very much. 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能 |
- [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- Re: [cgal-discuss] advice about CGAL Delaunay Triangulation, Andreas Fabri, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/03/2009
