cgal-discuss - Re: [cgal-discuss] advice about CGAL Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation
  • Date: Mon, 02 Feb 2009 15:51:19 +0100
Your code looks ok, and your machine has as much RAM as mine.
I guess you have to come up with a minimal code example
so that we can give it a try.
andreas
Kwok Jasper wrote:
> Thank you
> The code I am using is as follows
> typedef CGAL::Delaunay_triangulation_3<K1> Triangulations;
> typedef Triangulations::Point Point_tr;
> typedef Triangulations::Facet Facet;
> typedef Triangulations::Finite_facets_iterator finite_facets_itr;
> typedef Triangulations::Triangle Triangle;
> list<finite_facets_itr> temp;
> Triangle temp_triangle;
> double temp_circumradius = 0;
> double temp_max_inter_vertice_dist;
> finite_facets_itr starting_facet = Tr.finite_facets_begin();
> finite_facets_itr ending_facet = Tr.finite_facets_end();
> finite_facets_itr current_facet = starting_facet;
> for(current_facet = starting_facet; current_facet != ending_facet;
> ++current_facet)
> temp_triangle = Tr.tri angle(*current_facet);
> if ( .......)
> temp.push_back(current_facet);
> And I have attached in this email about the configuration of the machine
> I am using.
> Thank you very much
> > Date: Mon, 2 Feb 2009 15:09:11 +0100
> > From:
> > To:
> > Jasper,
> > The limitation of the std::list should be the virtual memory.
> > Concerning the Finite_faces_iterator, are you sure not
> > to forget to increment the iterator?
> > Can you send us the code of your loop.
> > < br>> I would be glad to know the configuration of your machine.
> > As you are on Windows, could you go to Start -> Control Panel -> System
> > and then tell us what is written in the tab 'General".
> > On my machine I see
> > System:
> > Microsoft Windows XP
> > Registered to:
> > Computer:
> > AMD Turion
> > ML 40
> > 2.19 GHz, 896 MB of RAM.
> > What is written there on your computer?
> > andreas
> > Kwok Jasper wrote:
> > > Excuse me, may I seek for some advise about using the Delaunay
> > > Triangulation?
> > > If I have the Delaunay Triangulation declared as follows
> > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1;
> > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulat ions;
> > > After I have inserted several ten thousand points into the
> > > triangulation, I use the Finite_facets_iterator to iterate over all of
> > > the triangular faces in the triangulation.
> > > For each of the triangular face, I check for some condition and if
> they
> > > satify the condition, I push then into a
> std::list<Finite_facets_iterator>
> > > However, when I use the std::list<Finite_facets_iterator> to store all
> > > those triangular face, I get the exception saying that memory for the
> > > program is used up.
> > > May I ask if it is that for huge number of points inserted into the
> > > Delaunay Triangulation, it is not recommended to use std::list or
> > > std::vector to store the above information?
> > > If it is not recommended, what structure may I use for the storage.
> > > ; Thank you very much.
> > > 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能
> > > <http://www.microsoft.com/windows/windowslive/>
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
