- To: <>
- Subject: RE: [cgal-discuss] advice about CGAL Delaunay Triangulation
- Date: Tue, 3 Feb 2009 12:54:47 +0800
- Importance: Normal
Thank you. I have tried the main roultine you suggested to me. it didn't get run out of memory In my code, I am using std::list<finite_facets_itr> inside the function void SamplePointSet::improve_triangulation() After that, in the function void SamplePointSet::check_for_voronoi_edge(list<finite_facets_itr>& temp) I use temp_triangle = Tr.triangle(*(*current_facet)); to retrieve the triangular face for each of the facet stored in the list. May I ask if it is possible that the running out of the memory is due to the fact that I used too many data structure to store the information about the 362272 data points? In fact in my whole program, in addition to using list<facet_iterator> I also used some other data structure to store some other information about those points inserted into the Triangulation Is that it is not advisable to use more than 3 or 4 of such data structure as the number of points is huge ? Thank you very much > Date: Mon, 2 Feb 2009 16:18:33 +0100 > From: > To: > Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation > > > If you have this > > main() > { > finite_facets_itr it = tr.finite_faces_begin(); > std::list<finite_facets_itr> facets; > > for(int i=0; true; i++){ > std::cout << "i = " << i << std::endl; > facets.push_back(it); > } > } > > do you then also run out of memory quickly? > > > Concerning your code, I only searched for finite_facets_itr > > I am wondering if you really want a std::list<finite_facets_itr>, > or if you want a std::list<Facet>. > > After all you don't want to iterate. > > > andreas > > > > Kwok Jasper wrote: > > Thank you very much. > > > > The code I pasted in the email before work with some data structure I > > defined. > > Tohave the whole code wroking to test, may I attach the whole cpp files > > here? > > > > Thank you very much for your help. > > > > > Date: Mon, 2 Feb 2009 15:51:19 +0100 > > > From: > > > To: > > > Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation > > > > > > > > > Your code looks ok, and your machine has as much RAM as mine. > > > > > > I guess you have to come up with a minimal code example > > > so that we can give it a try. > > > > > > andreas > > > > > > > > > Kwok Jasper wrote: > > > > Thank you > > > > > > > > The code I am using is as follows > > > > > > > > > > > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; > > > > typedef Triangulations::Point Point_tr; > > > > typedef Triangula tions::Facet Facet; > > > > typedef Triangulations::Finite_facets_iterator finite_facets_itr; > > > > typedef Triangulations::Triangle Triangle; > > > > > > > > list<finite_facets_itr> temp; > > > > Triangle temp_triangle; > > > > double temp_circumradius = 0; > > > > double temp_max_inter_vertice_dist; > > > > > > > > finite_facets_itr starting_facet = Tr.finite_facets_begin(); > > > > finite_facets_itr ending_facet = Tr.finite_facets_end(); > > > > finite_facets_itr current_facet = starting_facet; > > > > > > > > for(current_facet = starting_facet; current_facet != ending_facet; > > > > ++current_facet) > > > > { > > > > temp_triangle = Tr.tri angle(*current_facet); > > > > > > > > if ( .......) > > > > { > > > > temp.push_back(current_facet); > > > > } > > > > } > > > > > > > > > > > > And I have attached in this email about the configuration of the > > machine > > > > I am using. > > > > > > > > Thank you very much > > > > > > > > > > > > > > > > > Date: Mon, 2 Feb 2009 15:09:11 +0100 > > > > > From: > > > > > To: > > > > > Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation > > > > > > > > > > > > > > > Jasper, > > > > > > > > > > The limitation of the std::list should be the virtual memory. > > > > > > > > > > Concerning the Finite_faces_iterator, are you sure not > > > > > to forget to increment the iterator? > > > > > > > > > > Can you send us the code of your loop. > > > > > > > > > > > > > > > < br>> I would be glad to know the configu ration of your machine. > > > > > > > > > > As you are on Windows, could you go to Start -> Control Panel -> > > System > > > > > and then tell us what is written in the tab 'General". > > > > > > > > > > On my machine I see > > > > > > > > > > System: > > > > > Microsoft Windows XP > > > > > ... > > > > > > > > > > Registered to: > > > > > ... > > > > > > > > > > Computer: > > > > > AMD Turion > > > > > ML 40 > > > > > 2.19 GHz, 896 MB of RAM. > > > > > > > > > > > > > > > What is written there on your computer? > > > > > > > > > > andreas > > > > > > > > > > > > > > > > > > > > Kwok Jasper wrote: > > > > > > Excuse me, may I seek for some advise about using the Delaunay > > > > > > Triangulation? > > > > > &g t; > > > > > > If I have the Delaunay Triangulation declared as follows > > > > > > > > > > > > > > > > > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > > > > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulat ions; > > > > > > > > > > > > > > > > > > After I have inserted several ten thousand points into the > > > > > > triangulation, I use the Finite_facets_iterator to iterate over > > all of > > > > > > the triangular faces in the triangulation. > > > > > > For each of the triangular face, I check for some condition and if > > > > they > > > > > > satify the condition, I push then into a > > > > std::list<Finite_facets_iterator> > > > > > > > > > > > > However, when I use the std::list<Finite_facets_iterator> to > > store all > > > > > > those tr iangular face, I get the exception saying that memory > > for the > > > > > > program is used up. > > > > > > May I ask if it is that for huge number of points inserted into the > > > > > > Delaunay Triangulation, it is not recommended to use std::list or > > > > > > std::vector to store the above information? > > > > > > > > > > > > If it is not recommended, what structure may I use for the storage. > > > > > > > > > > > > ; Thank you very much. > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能 > > > > > > <http://www.microsoft.com/windows/windowslive/> > > > > > > > > > > -- > > > > > You are currently subscribed to cgal-discuss. > > > > > To unsubscribe or access the archives, go to > > > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > > > > > ------------------------------------------------------------------------ > > > > 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能 > > > > <http://www.microsoft.com/windows/windowslive/> > > > > > > ------------------------------------------------------------------------ > > > > > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives, go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > ------------------------------------------------------------------------ > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss 人與人之間的距離只有一指之隔。 |
- [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- Re: [cgal-discuss] advice about CGAL Delaunay Triangulation, Andreas Fabri, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/03/2009
