- To: <>
- Subject: RE: [cgal-discuss] advice about CGAL Delaunay Triangulation
- Date: Mon, 2 Feb 2009 22:56:35 +0800
- Importance: Normal
#include <string.h> /********************************************************SamplePoint.h******************************************************/ #include <fstream> #include <list> #include <CGAL/Delaunay_triangulation_3.h> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Fuzzy_sphere.h> #include <CGAL/Cartesian.h> #include <CGAL/Triangulation_hierarchy_3.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; //typedef CGAL::Cartesian<double> K1; /** #include <CGAL/Simple_cartesian.h> #include <CGAL/Filtered_kernel.h> typedef CGAL::Simple_cartesian<double> CK; typedef CGAL::Filtered_kernel<CK> K1; **/ /** typedef CGAL::Exact_predicates_inexact_constructions_kernel epick; typedef CGAL::Lazy_exact_nt<CGAL::Cartesian> K1; **/ /** #include <CGAL/MP_Float.h> #include <CGAL/Lazy_exact_nt.h> #include <CGAL/Quotient.h> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> typedef CGAL::Lazy_exact_nt<CGAL::Exact_predicates_inexact_constructions_kernel<double> > NT; typedef CGAL::Cartesian<NT> K1; **/ /** typedef CGAL::Triangulation_vertex_base_3<K1> Vb; typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh; typedef CGAL::Triangulation_data_structure_3<Vbh> Tds; typedef CGAL::Delaunay_triangulation_3<K1,Tds> Triangulation; typedef CGAL::Triangulation_hierarchy_3<Triangulation> Triangulations; **/ /** typedef CGAL::Delaunay_triangulation_3<K, Tds> Triangulation; typedef CGAL::Triangulation_hierarchy_3<Triangulation> Triangulations; **/ typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; typedef Triangulations::Point Point_tr; typedef Triangulations::Vertex Vertex; typedef Triangulations::Vertex_handle Vertex_handle; typedef Triangulations::Finite_vertices_iterator finite_vertices_itr; typedef Triangulations::Edge Edge; typedef Triangulations::Facet Facet; typedef Triangulations::Finite_facets_iterator finite_facets_itr; typedef Triangulations::Triangle Triangle; typedef Triangulations::Segment Segment; typedef CGAL::Cartesian<double> Rep_class; typedef Rep_class::Point_3 Point; typedef CGAL::Vector_3<Rep_class > Vector; //k-neighbour #include <CGAL/Orthogonal_k_neighbor_search.h> #include <CGAL/Search_traits_3.h> #include <math.h> #include <iostream> #include "mex.h" #include "find_surface_normal.h" using namespace std; class PriorityQueueForNeighborSearchNode { public: double key_dist; Point point; PriorityQueueForNeighborSearchNode(){} PriorityQueueForNeighborSearchNode(const double dist, const double x_i, const double y_i, const double z_i); PriorityQueueForNeighborSearchNode(const PriorityQueueForNeighborSearchNode& node_i); friend class PriorityQueueForNeighborSearchTree; }; PriorityQueueForNeighborSearchNode::PriorityQueueForNeighborSearchNode(const PriorityQueueForNeighborSearchNode& node_i) { point = Point(node_i.point.x(), node_i.point.y(), node_i.point.z()); key_dist = node_i.key_dist; } PriorityQueueForNeighborSearchNode::PriorityQueueForNeighborSearchNode(const double dist, const double x_i, const double y_i, const double z_i) { point = Point(x_i, y_i, z_i); key_dist = dist; } class PriorityQueueForNeighborSearchTree { private: vector<PriorityQueueForNeighborSearchNode> tree_content; PriorityQueueForNeighborSearchTree(); void insert(const double dist, const double x_i, const double y_i, const double z_i); Point delete_min(); }; PriorityQueueForNeighborSearchTree::PriorityQueueForNeighborSearchTree() { PriorityQueueForNeighborSearchNode node(-1, -1, -1, -1); tree_content.push_back(node); } void PriorityQueueForNeighborSearchTree::insert(const double dist, const double x_i, const double y_i, const double z_i) { //tree_content.resize(tree_content.size()); PriorityQueueForNeighborSearchNode node(dist, x_i, y_i, z_i); tree_content.push_back(node); PriorityQueueForNeighborSearchNode temp; for(int hole = tree_content.size()-1; ((hole > 1) && (tree_content.at(hole/2).key_dist > dist)); hole /= 2) { temp = tree_content.at(hole); tree_content.at(hole) = tree_content.at(hole/2); tree_content.at(hole/2) = temp; } } Point PriorityQueueForNeighborSearchTree::delete_min() { double tempX = tree_content.at(1).point.x(); double tempY = tree_content.at(1).point.y(); double tempZ = tree_content.at(1).point.z(); Point result(tempX, tempY, tempZ); tree_content.at(1) = tree_content.at(tree_content.size() - 1); tree_content.pop_back(); int child; PriorityQueueForNeighborSearchNode temp = tree_content.at(1); int hole = 1; for(hole = 1; ((hole * 2 <= tree_content.size() - 1) ); hole = child) { child = hole * 2; if ((child != tree_content.size() -1) && (tree_content.at(child+1).key_dist < tree_content.at(child).key_dist)) { ++child; } if (tree_content.at(child).key_dist < temp.key_dist) { tree_content.at(hole) = tree_content.at(child); } else { break; } } tree_content.at(hole) = temp; return result; } class SamplePoint { private: double sample_point[3]; //record the coordinate of the sample point double surface_normal[3]; //record the surface normal at the sample point list<Point> neighbour; //record the 55 nearest neighbour for the sample point double fifth_nearest_dist; //record the fifth nearest distance for the sample point SamplePoint(const double px, const double py, const double pz); void set_surface_normal(const double nx, const double ny, const double nz); double sample_point_x() const; double sample_point_y() const; double sample_point_z() const; double surface_normal_x() const; double surface_normal_y() const; double surface_normal_z() const; void set_fifth_nearest_dist(const double d); //void add_neighbour(SamplePoint p); void perturb_point(); friend class SamplePointSet; //friend class Construct_coord_iterator; friend class SamplePointKdTreeNode; }; /** class Construct_coord_iterator { public: const double* operator()(const SamplePoint& sp) const { return static_cast<const double*>(sp.sample_point); } const double* operator()(const SamplePoint& sp, int) const { return static_cast<const double*>(sp.sample_point+3); } }; **/ //k-neighbour typedef CGAL::Search_traits_3<Rep_class> Traits; typedef CGAL::Orthogonal_k_neighbor_search<Traits> Neighbor_search; typedef Neighbor_search::Tree Tree; typedef Tree::iterator Tree_itr; //typedef CGAL::Fuzzy_sphere<Traits> Fuzzy_sphere; Tree sample_point_tree_row; void SamplePoint::perturb_point() { Point p(sample_point[0], sample_point[1], sample_point[2]); Neighbor_search search(sample_point_tree_row, p, 2); Neighbor_search::iterator itr = search.begin(); ++itr; double dist = itr -> second; double disturbance = dist * (0 + rand() * (0.5) / RAND_MAX); //double disturbance = dist * ((rand() % 2 * 0.01) - (rand() % 2 * 0.01)); sample_point[0] += disturbance; //disturbance = dist * (-0.1 + rand() * 0.1); sample_point[1] += disturbance; //disturbance = dist * (-0.1 + rand() * 0.1); sample_point[2] += disturbance; } void SamplePoint::set_fifth_nearest_dist(const double d) { fifth_nearest_dist = d; } /** void SamplePoint::add_neighbour(SamplePoint p) { neighbour.push_back(p); } **/ SamplePoint::SamplePoint(const double px, const double py, const double pz) { sample_point[0] = px; sample_point[1] = py; sample_point[2] = pz; } void SamplePoint::set_surface_normal(const double nx, const double ny, const double nz) { surface_normal[0] = nx; surface_normal[1] = ny; surface_normal[2] = nz; } double SamplePoint::sample_point_x() const { return sample_point[0]; } double SamplePoint::sample_point_y() const { return sample_point[1]; } double SamplePoint::sample_point_z() const { return sample_point[2]; } double SamplePoint::surface_normal_x() const { return surface_normal[0]; } double SamplePoint::surface_normal_y() const { return surface_normal[1]; } double SamplePoint::surface_normal_z() const { return surface_normal[2]; } class SelectedTriangleElement { private: int facet_index; vector<int> vertice_index; SelectedTriangleElement(){} friend class SelectedTriangleSet; friend class SamplePointSet; }; class SelectedTriangleElementConnection { private: Point_tr vertice_1; Point_tr vertice_2; SelectedTriangleElementConnection(const Point_tr v1, const Point_tr v2); friend class SelectedTriangleSet; friend class SamplePointSet; }; SelectedTriangleElementConnection::SelectedTriangleElementConnection(const Point_tr v1, const Point_tr v2) { vertice_1 = v1; vertice_2 = v2; } class SelectedTriangleSet { private: vector<SelectedTriangleElement> triangle_set; vector<Point_tr> selected_vertice; vector<SelectedTriangleElementConnection> connection_edge; int num_of_facet; void add_vertice_to_set(const Point_tr v1, const Point_tr v2, const Point_tr v3); bool exist_vertice(const Point_tr query); int get_vertice_index(const Point_tr v); bool exist_connection_edge(const Point_tr query_1, const Point_tr query_2); int get_num_of_vertices() const; int get_num_of_edges() const; int get_num_of_facets() const; friend class SamplePointSet; }; int SelectedTriangleSet::get_num_of_vertices() const { return selected_vertice.size(); } int SelectedTriangleSet::get_num_of_edges() const { return (2 * (selected_vertice.size() - 3)); } int SelectedTriangleSet::get_num_of_facets() const { return (2 * (selected_vertice.size() - 2)); } int SelectedTriangleSet::get_vertice_index(const Point_tr v) { for(int i=0; i<selected_vertice.size(); ++i) { if ((selected_vertice.at(i).x() == v.x()) && (selected_vertice.at(i).y() == v.y()) && (selected_vertice.at(i).z() == v.z())) { return i; } } return -1; } bool SelectedTriangleSet::exist_connection_edge(const Point_tr query_1, const Point_tr query_2) { vector<SelectedTriangleElementConnection>::iterator ec_itr; bool b1; bool b2; bool b3; bool b4; bool b5; bool b6; for(ec_itr = connection_edge.begin(); ec_itr != connection_edge.end(); ++ec_itr) { b1 = (((ec_itr -> vertice_1).x() == query_1.x()) || ((ec_itr -> vertice_1).x() == query_2.x())); b2 = (((ec_itr -> vertice_1).y() == query_1.y()) || ((ec_itr -> vertice_1).y() == query_2.y())); b3 = (((ec_itr -> vertice_1).z() == query_1.z()) || ((ec_itr -> vertice_1).z() == query_2.z())); b4 = (((ec_itr -> vertice_2).x() == query_1.x()) || ((ec_itr -> vertice_2).x() == query_2.x())); b5 = (((ec_itr -> vertice_2).y() == query_1.y()) || ((ec_itr -> vertice_2).y() == query_2.y())); b6 = (((ec_itr -> vertice_2).z() == query_1.z()) || ((ec_itr -> vertice_2).z() == query_2.z())); if (b1 && b2 && b3 && b4 && b5 && b6) { return true; } } return false; } bool SelectedTriangleSet::exist_vertice(const Point_tr query) { vector<Point_tr>::iterator v_itr; for(v_itr = selected_vertice.begin(); v_itr != selected_vertice.end(); ++v_itr) { if (((v_itr -> x()) == query.x()) && ((v_itr -> y()) == query.y()) && ((v_itr -> z()) == query.z())) { return true; } } return false; } void SelectedTriangleSet::add_vertice_to_set(const Point_tr v1, const Point_tr v2, const Point_tr v3) { SelectedTriangleElement e; if (!(exist_vertice(v1))) { selected_vertice.push_back(v1); } if (!(exist_vertice(v2))) { selected_vertice.push_back(v2); } if (!(exist_vertice(v3))) { selected_vertice.push_back(v3); } e.vertice_index.push_back(get_vertice_index(v1)); e.vertice_index.push_back(get_vertice_index(v2)); e.vertice_index.push_back(get_vertice_index(v3)); triangle_set.push_back(e); /** if (!(exist_connection_edge(v1, v2))) { SelectedTriangleElementConnection ec(v1, v2); connection_edge.push_back(ec); } if (!(exist_connection_edge(v1, v3))) { SelectedTriangleElementConnection ec(v1, v3); connection_edge.push_back(ec); } if (!(exist_connection_edge(v2, v3))) { SelectedTriangleElementConnection ec(v2, v3); connection_edge.push_back(ec); } **/ } class SamplePointKdTreeNode { private: SamplePoint * node; SamplePointKdTreeNode * left; SamplePointKdTreeNode * right; SamplePointKdTreeNode() : node(NULL), left(NULL), right(NULL){} void insert(SamplePointKdTreeNode * curr_node, SamplePoint * p, int dim=0); SamplePoint * get_sample_point_by_coordinate(SamplePointKdTreeNode * curr_node, double x_1, double y_1, double z_i, int dim=0); friend class SamplePointSet; }; void SamplePointKdTreeNode::insert(SamplePointKdTreeNode * curr_node, SamplePoint * p, int dim) { SamplePointKdTreeNode * next_node = curr_node; if (next_node -> node == NULL) { next_node -> node = p; } else { switch (dim) { case 0: if (curr_node -> node -> sample_point_x() < p -> sample_point_x()) { if (next_node -> left == NULL) { next_node -> left = new SamplePointKdTreeNode(); } next_node = next_node -> left; } else { if (next_node -> right == NULL) { next_node -> right = new SamplePointKdTreeNode(); } next_node = next_node -> right; } break; case 1: if (curr_node -> node -> sample_point_y() < p -> sample_point_y()) { if (next_node -> left == NULL) { next_node -> left = new SamplePointKdTreeNode(); } next_node = next_node -> left; } else { if (next_node -> right == NULL) { next_node -> right = new SamplePointKdTreeNode(); } next_node = next_node -> right; } break; case 2: if (curr_node -> node -> sample_point_z() < p -> sample_point_z()) { if (next_node -> left == NULL) { next_node -> left = new SamplePointKdTreeNode(); } next_node = next_node -> left; } else { if (next_node -> right == NULL) { next_node -> right = new SamplePointKdTreeNode(); } next_node = next_node -> right; } break; } insert(next_node, p, (dim + 1) % 3); } } SamplePoint * SamplePointKdTreeNode::get_sample_point_by_coordinate(SamplePointKdTreeNode * curr_node, double x_i, double y_i, double z_i, int dim) { SamplePointKdTreeNode * next_node = curr_node; if (next_node -> node == NULL) { cerr << "attempting to search for a sample point that does not exist" << endl; system("pause"); exit(1); } else if ((next_node -> node -> sample_point_x() == x_i) && (next_node -> node -> sample_point_y() == y_i) && (next_node -> node -> sample_point_z() == z_i)) { return next_node -> node; } else { switch (dim) { case 0: if (curr_node -> node -> sample_point_x() < x_i) { next_node = next_node -> left; } else { next_node = next_node -> right; } break; case 1: if (curr_node -> node -> sample_point_y() < y_i) { next_node = next_node -> left; } else { next_node = next_node -> right; } break; case 2: if (curr_node -> node -> sample_point_z() < z_i) { next_node = next_node -> left; } else { next_node = next_node -> right; } break; } return get_sample_point_by_coordinate(next_node, x_i, y_i, z_i, (dim + 1) % 3); } } class SamplePointSet { private: list<Point_tr> sample_point_data; list<SamplePoint> sample_point_list; SelectedTriangleSet improved_triangulation; Tree sample_point_tree_final; Triangulations Tr; SamplePointKdTreeNode * root; void build_surface_normal(); double squared_distance(const Point p1, const Point p2) const; void add_sample(const double px, const double py, const double pz); void improve_triangulation(); void check_for_circumradius(list<finite_facets_itr>& temp); void check_for_voronoi_edge(list<finite_facets_itr>& temp); double max_of_three(const double d1, const double d2, const double d3) const; void find_fifth_nearest_dist(); void search_nearest_neighbour(const int num_of_neighbour); double implicit_function(list<SamplePoint * > pl, const Point query); void create_triangulation_file(const char * const file) const; void get_sample_point(const char * const file_source); void compute_surface_normal(SamplePoint& sp, const double x_variance, const double y_variance, const double z_variance, const double x_y_covariance, const double y_z_covariance, const double x_z_covariance); SamplePoint get_sample_point_from_point(Point p); //SamplePoint * get_sample_point_by_coordinate(const double x_i, const double y_i, const double z_i); //SamplePoint * get_sample_point_by_coordinate_operation(const double x_i, const double y_i, const double z_i, const int dim, Tree_itr ref); public: SamplePointSet(); void get_triangulation(const char * const file_source, const char * const file_result); }; SamplePointSet::SamplePointSet() { root = new SamplePointKdTreeNode(); } void SamplePointSet::create_triangulation_file(const char * const file_result) const { ofstream output_file; output_file.open(file_result); output_file << "OFF\n"; output_file << improved_triangulation.get_num_of_vertices() << ' ' << improved_triangulation.get_num_of_facets() << ' ' << improved_triangulation.get_num_of_edges() << '\n'; for(int i=0; i<improved_triangulation.selected_vertice.size(); ++i) { output_file << improved_triangulation.selected_vertice.at(i).x() << ' ' << improved_triangulation.selected_vertice.at(i).y() << ' ' << improved_triangulation.selected_vertice.at(i).z() << '\n'; } for(int i = 0; i < improved_triangulation.triangle_set.size(); ++i) { output_file << "3 "; for(int j = 0; j < improved_triangulation.triangle_set.at(i).vertice_index.size(); ++j) { output_file << improved_triangulation.triangle_set.at(i).vertice_index.at(j) << ' '; } output_file << '\n'; } output_file.close(); } void SamplePointSet::get_triangulation(const char * const file_source,const char * const file_result) { if( !mclInitializeApplication(NULL,0) ) { fprintf(stderr, "Could not initialize the application.\n"); system("pause"); exit(1); } if (!find_surface_normalInitialize()) { fprintf(stderr,"Could not initialize the library.\n"); system("pause"); exit(1); } cout << "getting sample point input ....." << endl; get_sample_point(file_source); list<SamplePoint>::iterator start = sample_point_list.begin(); list<SamplePoint>::iterator end = sample_point_list.end(); list<SamplePoint>::iterator curr; Tr.insert(sample_point_data.begin(), sample_point_data.end()); sample_point_data.clear(); /** cout << "perturbing sample points ..... " << endl; for(curr = start; curr != end; ++curr) { curr -> perturb_point(); } cout << "rebuilding search tree ....." << endl; for(curr = start; curr != end; ++curr) { double tempX = curr -> sample_point_x(); double tempY = curr -> sample_point_y(); double tempZ = curr -> sample_point_z(); Point p(tempX, tempY, tempZ); sample_point_tree_final.insert(p); } **/ cout << "initializing neighbour and distance ....." << endl; search_nearest_neighbour(55); find_fifth_nearest_dist(); //sample_point_tree_final.clear(); /** for(curr = start; curr != end; ++curr) { cout << "here" << endl; curr -> neighbour = search_nearest_neighbour(*curr, 55); cout << "sdfsasdaa" << endl; cout << ++i << endl; curr -> set_fifth_nearest_dist(find_fifth_nearest_dist(*curr)); cout << "there" << endl; } **/ cout << "rebuilding search tree ....." << endl; int i=0; for(curr = start; curr != end; ++curr) { cout << ++i << "RST" << endl; root -> insert(root, &(*curr)); } /** cout << "building row triangulation ....." << endl; for(curr = start; curr != end; ++curr) { cout << "here" << endl; double tempX = curr -> sample_point_x(); double tempY = curr -> sample_point_y(); double tempZ = curr -> sample_point_z(); Tr.insert(Point_tr(tempX, tempY, tempZ)); } **/ cout << "computing surface normal ....." << endl; build_surface_normal(); cout << "improving triangulation ..." << endl; improve_triangulation(); cout << "creating off files ... " << endl; create_triangulation_file(file_result); cout << "Done" << endl; find_surface_normalTerminate(); mclTerminateApplication(); } void SamplePointSet::improve_triangulation() { /** list<finite_facets_itr> temp; check_for_circumradius(temp); check_for_voronoi_edge(temp); **/ Triangle temp_triangle; double temp_circumradius = 0; double temp_max_inter_vertice_dist; finite_facets_itr starting_facet = Tr.finite_facets_begin(); finite_facets_itr ending_facet = Tr.finite_facets_end(); finite_facets_itr current_facet = starting_facet; int i=0; for(current_facet = starting_facet; current_facet != ending_facet; ++current_facet) { cout << ++i << "CCR" << endl; temp_triangle = Tr.triangle(*current_facet); improved_triangulation.add_vertice_to_set(temp_triangle.vertex(0), temp_triangle.vertex(1), temp_triangle.vertex(2)); cout << improved_triangulation.selected_vertice.size() << "SSSSSSSSSSSSSSS" << endl; } } void SamplePointSet::check_for_circumradius(list<finite_facets_itr>& temp) { Triangle temp_triangle; double temp_circumradius = 0; double temp_max_inter_vertice_dist; finite_facets_itr starting_facet = Tr.finite_facets_begin(); finite_facets_itr ending_facet = Tr.finite_facets_end(); finite_facets_itr current_facet = starting_facet; double d1; double d2; double d3; int i=0; for(current_facet = starting_facet; current_facet != ending_facet; ++current_facet) { cout << ++i << "CCR" << endl; temp_triangle = Tr.triangle(*current_facet); /** temp_max_inter_vertice_dist = max_of_three(find_fifth_nearest_dist(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z())) * 3, find_fifth_nearest_dist(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z())) * 3, find_fifth_nearest_dist(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z())) * 3); **/ /** Fuzzy_sphere sp1(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z()), 0, 0); Fuzzy_sphere sp2(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z()), 0, 0); Fuzzy_sphere sp3(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z()), 0, 0); Tree::iterator temp_vertice1 = final_tree.search(Tree::iterator temp_vertice1, sp1); std::ostream_iterator<SamplePoint> temp_vertice2 = final_tree.search(std::ostream_iterator<SamplePoint>(std::cout, "\n"), sp2); std::ostream_iterator<SamplePoint> temp_vertice3 = final_tree.search(std::ostream_iterator<SamplePoint>(std::cout, "\n"), sp3); temp_max_inter_vertice_dist = max_of_three(temp_vertice_1 -> fifth_nearest_dist, temp_vertice_2 -> fifth_nearest_dist, temp_vertice_3 -> fifth_nearest_dist); **/ d1 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z()) -> fifth_nearest_dist; d2 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z()) -> fifth_nearest_dist; d3 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z()) -> fifth_nearest_dist; d1 *= 3; d2 *= 3; d3 *= 3; temp_max_inter_vertice_dist = max_of_three(d1, d2, d3); temp_circumradius = (squared_radius(temp_triangle.vertex(0), temp_triangle.vertex(1), temp_triangle.vertex(2))); cout << "d1: " << d1 << endl; cout << "d2: " << d2 << endl; cout << "d3: " << d3 << endl; cout << "temp_circumradius: " << temp_circumradius << endl; cout << "temp_max_inter_vertice_dist: " << temp_max_inter_vertice_dist << endl; cout << "***************" << temp.size() << endl; if (temp_circumradius <= temp_max_inter_vertice_dist) { cout << "triangle filtered" << endl; temp.push_back(current_facet); /** improved_triangulation.add_vertice_to_set(temp_triangle.vertex(0), temp_triangle.vertex(1), temp_triangle.vertex(2), facet_index); ++facet_index; **/ //improved_triangulation.add_vertice_to_set(temp_triangle.vertex(0), temp_triangle.vertex(1), temp_triangle.vertex(2)); } } } void SamplePointSet::check_for_voronoi_edge(list<finite_facets_itr>& temp) { cout << temp.size() << endl; cout << "vornoi"<< endl; system("pause"); Triangle temp_triangle; Segment temp_dual_voronoi_edge_of_triangle; CGAL::Object obj; list<Point>::iterator pl_itr; list<finite_facets_itr>::iterator starting_facet = temp.begin(); list<finite_facets_itr>::iterator ending_facet = temp.end(); list<finite_facets_itr>::iterator current_facet; int i=0; for(current_facet = starting_facet; current_facet != ending_facet; ++current_facet) { cout << ++i << "CFVE" << endl; list<Point> temp_neighbour_list_1; list<Point> temp_neighbour_list_2; list<Point> temp_neighbour_list_3; list<SamplePoint *> point_set; temp_triangle = Tr.triangle(*(*current_facet)); /** temp_neighbour_list_1 = (search_nearest_neighbour(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z()), 15)); temp_neighbour_list_1.push_back(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z())); temp_neighbour_list_2 = (search_nearest_neighbour(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z()), 15)); temp_neighbour_list_2.push_back(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z())); temp_neighbour_list_3 = (search_nearest_neighbour(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z()), 15)); temp_neighbour_list_3.push_back(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z())); **/ /** temp_neighbour_list_1 = final_tree.search(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z()), 0); //temp_neighbour_list_1.push_back(SamplePoint(temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z())); temp_neighbour_list_2 = final_tree.search(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z()), 0); //temp_neighbour_list_2.push_back(SamplePoint(temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z())); temp_neighbour_list_3 = final_tree.search(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z()), 0); //temp_neighbour_list_3.push_back(SamplePoint(temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z())); **/ temp_neighbour_list_1 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(0).x(), temp_triangle.vertex(0).y(), temp_triangle.vertex(0).z()) -> neighbour; temp_neighbour_list_2 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(1).x(), temp_triangle.vertex(1).y(), temp_triangle.vertex(1).z()) -> neighbour; temp_neighbour_list_3 = root -> get_sample_point_by_coordinate(root, temp_triangle.vertex(2).x(), temp_triangle.vertex(2).y(), temp_triangle.vertex(2).z()) -> neighbour; double tempX; double tempY; double tempZ; for(pl_itr = temp_neighbour_list_1.begin(); pl_itr != temp_neighbour_list_1.end(); ++pl_itr) { tempX = pl_itr -> x(); tempY = pl_itr -> y(); tempZ = pl_itr -> z(); point_set.push_back( root -> get_sample_point_by_coordinate(root, tempX, tempY, tempZ)); //point_set.push_back(*pl_itr); } for(pl_itr = temp_neighbour_list_2.begin(); pl_itr != temp_neighbour_list_2.end(); ++pl_itr) { tempX = pl_itr -> x(); tempY = pl_itr -> y(); tempZ = pl_itr -> z(); point_set.push_back( root -> get_sample_point_by_coordinate(root, tempX, tempY, tempZ)); //point_set.push_back(*pl_itr); } for(pl_itr = temp_neighbour_list_3.begin(); pl_itr != temp_neighbour_list_3.end(); ++pl_itr) { tempX = pl_itr -> x(); tempY = pl_itr -> y(); tempZ = pl_itr -> z(); point_set.push_back( root -> get_sample_point_by_coordinate(root, tempX, tempY, tempZ)); //point_set.push_back(*pl_itr); } obj = Tr.dual(*(*current_facet)); double temp_start; double temp_end; if (assign(temp_dual_voronoi_edge_of_triangle, obj)) { temp_start = implicit_function(point_set, Point(temp_dual_voronoi_edge_of_triangle.start().x(), temp_dual_voronoi_edge_of_triangle.start().y(), temp_dual_voronoi_edge_of_triangle.start().z())); temp_end = implicit_function(point_set, Point(temp_dual_voronoi_edge_of_triangle.end().x(), temp_dual_voronoi_edge_of_triangle.end().y(), temp_dual_voronoi_edge_of_triangle.end().z())); if (temp_start * temp_end < 0) { improved_triangulation.add_vertice_to_set(temp_triangle.vertex(0), temp_triangle.vertex(1), temp_triangle.vertex(2)); } } } } double SamplePointSet::implicit_function(list<SamplePoint *> pl, const Point query) { cout << "start IF" << endl; double result = 0; double result_temp_1 = 0; double result_temp_2 = 0; double weight_temp_1 = 0; double weight_temp_2 = 0; double weight_power_1 = 0; double weight_power_2 = 0; double fifth_nearest_dist_of_query= 0; double total = 0; /** Neighbor_search search(sample_point_tree_final, query, 5); Neighbor_search::iterator itr; int i=0; for(itr = search.begin(); itr != search.end(); ++itr) { ++i; if (i == 5) { break; } } fifth_nearest_dist_of_query = itr -> second; **/ //fifth_nearest_dist_of_query = find_fifth_nearest_dist(query); list<SamplePoint* >::iterator p_itr; //list<SamplePoint* > sp; //list<SamplePoint>::iterator sp_itr; /** for(p_itr = pl.begin(); p_itr != pl.end(); ++p_itr) { sp.push_back(get_sample_point_from_point(*p_itr)); } **/ for(p_itr = pl.begin(); p_itr != pl.end(); ++p_itr) { weight_power_1 = pow(( (*p_itr) -> sample_point_x() - query.x()), 2); weight_power_1 += pow(( (*p_itr) -> sample_point_y() - query.y()), 2); weight_power_1 += pow(( (*p_itr) -> sample_point_z() - query.z()), 2); weight_power_1 = sqrt(weight_power_1); weight_power_1 /= fifth_nearest_dist_of_query; weight_power_1 = pow(weight_power_1, 2); weight_power_1 *= -1; weight_temp_1 += exp(weight_power_1); } for(p_itr = pl.begin(); p_itr != pl.end(); ++p_itr) { weight_power_2 = pow(( (*p_itr) -> sample_point_x() - query.x()), 2); weight_power_2 += pow(( (*p_itr) -> sample_point_y() - query.y()), 2); weight_power_2 += pow(( (*p_itr) -> sample_point_z() - query.z()), 2); weight_power_2 = sqrt(weight_power_2); weight_power_2 /= fifth_nearest_dist_of_query; weight_power_2 = pow(weight_power_1, 2); weight_power_2 *= -1; weight_temp_2 = exp(weight_power_2); result_temp_1 = weight_temp_2 / weight_temp_1; result_temp_2 = ( (*p_itr) -> surface_normal_x()) * (query.x() - ( (*p_itr) -> sample_point_x())); result_temp_2 += ( (*p_itr) -> surface_normal_y()) * (query.y() - ( (*p_itr) -> sample_point_y())); result_temp_2 += ( (*p_itr) -> surface_normal_z()) * (query.z() - ( (*p_itr) -> sample_point_z())); result += result_temp_1 * result_temp_2; } cout << "end_IF" << endl; return result; } double SamplePointSet::max_of_three(const double d1, const double d2, const double d3) const { if ((d1 >= d2) && (d1 >= d3)) { return d1; } else if ((d2 >= d1) && (d2 >= d3)) { return d2; } else { return d3; } } void SamplePointSet::get_sample_point(const char * const file_source) { ifstream inFile; //stream for reading sample data points from a file inFile.open(file_source); //open the file storing the input sample points if (!inFile) { //return erorr message and terminate the program iff the file containing the sample point data cannot be opened succssfully. cerr << "Unable to open file containing the sample point data"; system("pause"); exit(1); } double tempI; //variable for holding the data currently read from the input file double tempX = 0; //variable for string the x-copordinate of a sample point, which is read from the input file double tempY = 0; //variable for string the y-copordinate of a sample point, which is read from the input file double tempZ = 0; //variable for string the z-copordinate of a sample point, which is read from the input file int tempCounter = 0; /**variable for recording wehther the program is current reading an x-coordinate, y-coordinate or z-coordinate from a file If it has the value of 0, then it indicates that the porgramme is reading an x-coordinate If it has the value of 1, then it indicates that the porgramme is reading an y-coordinate If it has the value of 2, then it indicates that the porgramme is reading an z-coordinate **/ int i=0; while (!inFile.eof()) { //read the sample data points inFile >> tempI; if (tempCounter == 0) { tempX = tempI; tempCounter = 1; } else if (tempCounter == 1) { tempY = tempI; tempCounter = 2; } else if (tempCounter == 2) { cout << ++i << endl; tempZ = tempI; add_sample(tempX, tempY, tempZ); tempCounter = 0; } } inFile.close(); } void SamplePointSet::add_sample(const double px, const double py, const double pz) { SamplePoint p(px, py, pz); //initalize a SamplePoint object for the inout point sample_point_list.push_back(p); //add the SamplePoint object representing the sample point into the list of SamplePoint Point_tr pi(px, py, pz); sample_point_data.push_back(pi); //Tr.insert(Point_tr(px, py, pz)); //add the sample point into the triangulation sample_point_tree_final.insert(Point(px, py, pz)); } double SamplePointSet::squared_distance(const Point p1, const Point p2) const { double result = 0; result += p1.x() * p2.x(); result += p1.y() * p2.y(); result += p1.z() * p2.z(); return result; } void SamplePointSet::build_surface_normal() { cout << "BSN start" << endl; vector<double> temp_neighbour_dist; double temp_fifth_nearest_dist = 0; list<Point> co_input; //input for covriance matrix() calculation Point co_mean; //mean vector for covarience matrix() calculation double x_total = 0; //mean vector calculation double y_total = 0; //mean vector calculation double z_total = 0; //mean vector calculation double x_variance = 0; double y_variance = 0; double z_variance = 0; double x_y_covariance = 0; double y_z_covariance = 0; double x_z_covariance = 0; list<SamplePoint>::iterator sample_point_set_itr1; list<SamplePoint *>::iterator sample_point_set_itr2; list<Point>::iterator co_itr; list<Point> neighbour_temp; int i=0; for(sample_point_set_itr1 = sample_point_list.begin(); sample_point_set_itr1 != sample_point_list.end(); ++sample_point_set_itr1) { cout << ++i << "CSN " << endl; temp_fifth_nearest_dist = 0; list<Point> co_input; //input for covriance matrix() calculation x_total = 0; //mean vector calculation y_total = 0; //mean vector calculation z_total = 0; //mean vector calculation x_variance = 0; y_variance = 0; z_variance = 0; x_y_covariance = 0; y_z_covariance = 0; x_z_covariance = 0; /** temp_fifth_nearest_dist = find_fifth_nearest_dist(SamplePoint(sample_point_set_itr1 -> sample_point_x(), sample_point_set_itr1 -> sample_point_y(), sample_point_set_itr1 -> sample_point_z())); neighbour = search_nearest_neighbour(*sample_point_set_itr1, 8); **/ /** neighbour = root -> get_sample_point_by_coordinate(root, sample_point_set_itr1 -> sample_point_x(), sample_point_set_itr1 -> sample_point_y(), sample_point_set_itr1 -> sample_point_z()) -> neighbour; **/ temp_fifth_nearest_dist = sample_point_set_itr1 -> fifth_nearest_dist; neighbour_temp = sample_point_set_itr1 -> neighbour; list<SamplePoint *> neighbour; list<Point>::iterator itr; for (itr = neighbour_temp.begin(); itr != neighbour_temp.end(); ++itr) { neighbour.push_back(root -> get_sample_point_by_coordinate(root, itr -> x(),itr -> y(), itr -> z())); } for(sample_point_set_itr2 = neighbour.begin(); sample_point_set_itr2 != neighbour.end(); ++sample_point_set_itr2) { double dist = pow((sample_point_set_itr1 -> sample_point_x() - (*sample_point_set_itr2) -> sample_point_x()), 2); dist += pow((sample_point_set_itr1 -> sample_point_y() - (*sample_point_set_itr2) -> sample_point_y()), 2); dist += pow((sample_point_set_itr1 -> sample_point_z() - (*sample_point_set_itr2) -> sample_point_z()), 2); dist = sqrt(dist); if((dist <= temp_fifth_nearest_dist * 3) && (dist != 0)) { double diffX = ((*sample_point_set_itr2) -> sample_point_x()) - (sample_point_set_itr1 -> sample_point_x()); double diffY = ((*sample_point_set_itr2) -> sample_point_y()) - (sample_point_set_itr1 -> sample_point_y()); double diffZ = ((*sample_point_set_itr2) -> sample_point_z()) - (sample_point_set_itr1 -> sample_point_z()); co_input.push_back(Point(diffX, diffY, diffZ)); } } for(co_itr = co_input.begin(); co_itr != co_input.end(); ++co_itr) { x_total += co_itr -> x(); y_total += co_itr -> y(); z_total += co_itr -> z(); } co_mean = Point((x_total/co_input.size()), (y_total/co_input.size()), (z_total/co_input.size())); for(co_itr = co_input.begin(); co_itr != co_input.end(); ++co_itr) { x_variance += ((co_itr -> x()) - (co_mean.x())) * ((co_itr -> x()) - (co_mean.x())); y_variance += ((co_itr -> y()) - (co_mean.y())) * ((co_itr -> y()) - (co_mean.y())); z_variance += ((co_itr -> z()) - (co_mean.z())) * ((co_itr -> z()) - (co_mean.z())); x_y_covariance += ((co_itr -> x()) - (co_mean.x())) * ((co_itr -> y()) - (co_mean.y())); y_z_covariance += ((co_itr -> y()) - (co_mean.y())) * ((co_itr -> z()) - (co_mean.z())); x_z_covariance += ((co_itr -> x()) - (co_mean.x())) * ((co_itr -> z()) - (co_mean.z())); } x_variance /= (co_input.size() -1); y_variance /= (co_input.size() -1); z_variance /= (co_input.size() -1); x_y_covariance /= (co_input.size() -1); y_z_covariance /= (co_input.size() -1); x_z_covariance /= (co_input.size() -1); sample_point_set_itr1 -> set_surface_normal(0,0,0); compute_surface_normal(*(sample_point_set_itr1), x_variance, y_variance, z_variance, x_y_covariance, y_z_covariance, x_z_covariance); } cout << "BSN end" << endl; } void SamplePointSet::compute_surface_normal(SamplePoint& sp, const double x_variance, const double y_variance, const double z_variance, const double x_y_covariance, const double y_z_covariance, const double x_z_covariance) { mxArray * input[9]; mxArray * output = NULL; double * result; double normal_component_1; double normal_component_2; double normal_component_3; input[0] = mxCreateDoubleScalar(x_variance); input[1] = mxCreateDoubleScalar(x_y_covariance); input[2] = mxCreateDoubleScalar(x_z_covariance); input[3] = mxCreateDoubleScalar(x_y_covariance); input[4] = mxCreateDoubleScalar(y_variance); input[5] = mxCreateDoubleScalar(y_z_covariance); input[6] = mxCreateDoubleScalar(x_z_covariance); input[7] = mxCreateDoubleScalar(y_z_covariance); input[8] = mxCreateDoubleScalar(z_variance); mlfFind_surface_normal(1,&output,input[0], input[1], input[2], input[3], input[4], input[5], input[6], input[7], input[8]); result = mxGetPr(output); normal_component_1 = *(result); normal_component_2 = *(result + 1); normal_component_3 = *(result + 2); sp.set_surface_normal(normal_component_1, normal_component_2, normal_component_3); mxDestroyArray(input[0]); mxDestroyArray(input[1]); mxDestroyArray(input[2]); mxDestroyArray(input[3]); mxDestroyArray(input[4]); mxDestroyArray(input[5]); mxDestroyArray(input[6]); mxDestroyArray(input[7]); mxDestroyArray(input[8]); mxDestroyArray(output); } void SamplePointSet::search_nearest_neighbour(const int num_of_neighbour) { cout << "SNN start" << endl; list<SamplePoint>::iterator start = sample_point_list.begin(); list<SamplePoint>::iterator end = sample_point_list.end(); list<SamplePoint>::iterator curr; Neighbor_search * search; Point * query; Neighbor_search::iterator itr; int i=0; for(curr = start; curr != end; ++curr) { cout << ++i << endl; query = new Point(curr -> sample_point_x(), curr -> sample_point_y(), curr -> sample_point_z()); search = new Neighbor_search(sample_point_tree_final, *query, num_of_neighbour); for (itr = search -> begin(); itr != search -> end(); ++itr) { (curr -> neighbour).push_back(itr -> first); } delete query; delete search; query = NULL; search = NULL; } /** Neighbor_search search(sample_point_tree_final, query_point, num_of_neighbour); list<Point> result_neighbour; Neighbor_search::iterator itr = search.begin(); int i=0; for(i=0, itr = search.begin(); itr != search.end(); ++itr) { if (i == num_of_neighbour) { break; } result_neighbour.push_back(itr->first); ++i; } **/ cout << "SNN end" << endl; //return result_neighbour; } void SamplePointSet::find_fifth_nearest_dist() { list<SamplePoint>::iterator start = sample_point_list.begin(); list<SamplePoint>::iterator end = sample_point_list.end(); list<SamplePoint>::iterator curr; Neighbor_search * search; Point * query; Neighbor_search::iterator itr; int i=0; for(curr = start; curr != end; ++curr) { query = new Point(curr -> sample_point_x(), curr -> sample_point_y(), curr -> sample_point_z()); search = new Neighbor_search(sample_point_tree_final, *query, 6); i=0; for (itr = search -> begin(); itr != search -> end(); ++itr) { ++i; if (i == 5) { break; } } (curr -> fifth_nearest_dist) = itr -> second; delete query; delete search; query = NULL; search = NULL; } /** Neighbor_search search(sample_point_tree_final, p, 5); Neighbor_search::iterator itr = search.begin(); int i=0; for(itr = search.begin(); itr != search.end(); ++itr) { ++i; if(i == 5) { break; } } return itr -> second; **/ } /********************************************************SamplePoint.h******************************************************/ int main() { SamplePointSet sample; sample.get_triangulation("C:\\bunny.txt", "C:\\result3.off"); system("pause"); return 0; }
- [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- Re: [cgal-discuss] advice about CGAL Delaunay Triangulation, Andreas Fabri, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/03/2009
