- To:
- Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation
- Date: Mon, 02 Feb 2009 15:09:11 +0100
Jasper,
The limitation of the std::list should be the virtual memory.
Concerning the Finite_faces_iterator, are you sure not
to forget to increment the iterator?
Can you send us the code of your loop.
I would be glad to know the configuration of your machine.
As you are on Windows, could you go to Start -> Control Panel -> System
and then tell us what is written in the tab 'General".
On my machine I see
System:
Microsoft Windows XP
Registered to:
Computer:
AMD Turion
ML 40
2.19 GHz, 896 MB of RAM.
What is written there on your computer?
andreas
Kwok Jasper wrote:
> Excuse me, may I seek for some advise about using the Delaunay
> Triangulation?
> If I have the Delaunay Triangulation declared as follows
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K1;
> typedef CGAL::Delaunay_triangulation_3<K1> Triangulations;
> After I have inserted several ten thousand points into the
> triangulation, I use the Finite_facets_iterator to iterate over all of
> the triangular faces in the triangulation.
> For each of the triangular face, I check for some condition and if they
> satify the condition, I push then into a std::list<Finite_facets_iterator>
> However, when I use the std::list<Finite_facets_iterator> to store all
> those triangular face, I get the exception saying that memory for the
> program is used up.
> May I ask if it is that for huge number of points inserted into the
> Delaunay Triangulation, it is not recommended to use std::list or
> std::vector to store the above information?
> If it is not recommended, what structure may I use for the storage.
> Thank you very much.
> 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能
> <http://www.microsoft.com/windows/windowslive/>
- [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- Re: [cgal-discuss] advice about CGAL Delaunay Triangulation, Andreas Fabri, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/03/2009
