- To: <>
- Subject: RE: [cgal-discuss] advice about CGAL Delaunay Triangulation
- Date: Mon, 2 Feb 2009 22:41:41 +0800
- Importance: Normal
Thank you The code I am using is as follows typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; typedef Triangulations::Point Point_tr; typedef Triangulations::Facet Facet; typedef Triangulations::Finite_facets_iterator finite_facets_itr; typedef Triangulations::Triangle Triangle; list<finite_facets_itr> temp; Triangle temp_triangle; double temp_circumradius = 0; double temp_max_inter_vertice_dist; finite_facets_itr starting_facet = Tr.finite_facets_begin(); finite_facets_itr ending_facet = Tr.finite_facets_end(); finite_facets_itr current_facet = starting_facet; for(current_facet = starting_facet; current_facet != ending_facet; ++current_facet) { temp_triangle = Tr.triangle(*current_facet); if ( .......) { temp.push_back(current_facet); } } And I have attached in this email about the configuration of the machine I am using. Thank you very much > Date: Mon, 2 Feb 2009 15:09:11 +0100 > From: > To: > Subject: Re: [cgal-discuss] advice about CGAL Delaunay Triangulation > > > Jasper, > > The limitation of the std::list should be the virtual memory. > > Concerning the Finite_faces_iterator, are you sure not > to forget to increment the iterator? > > Can you send us the code of your loop. > > > > I would be glad to know the configuration of your machine. > > As you are on Windows, could you go to Start -> Control Panel -> System > and then tell us what is written in the tab 'General". > > On my machine I see > > System: > Microsoft Windows XP > ... > > Registered to: > ... > > Computer: > AMD Turion > ML 40 > 2.19 GHz, 896 MB of RAM. > > > What is written there on your computer? > > andreas > > > > Kwok Jasper wrote: > > Excuse me, may I seek for some advise about using the Delaunay > > Triangulation? > > > > If I have the Delaunay Triangulation declared as follows > > > > > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; > > > > > > After I have inserted several ten thousand points into the > > triangulation, I use the Finite_facets_iterator to iterate over all of > > the triangular faces in the triangulation. > > For each of the triangular face, I check for some condition and if they > > satify the condition, I push then into a std::list<Finite_facets_iterator> > > > > However, when I use the std::list<Finite_facets_iterator> to store all > > those triangular face, I get the exception saying that memory for the > > program is used up. > > May I ask if it is that for huge number of points inserted into the > > Delaunay Triangulation, it is not recommended to use std::list or > > std::vector to store the above information? > > > > If it is not recommended, what structure may I use for the storage. > > > > Thank you very much. > > > > ------------------------------------------------------------------------ > > 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能 > > <http://www.microsoft.com/windows/windowslive/> > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss 收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能 |
Description: JPEG image
- [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- Re: [cgal-discuss] advice about CGAL Delaunay Triangulation, Andreas Fabri, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/02/2009
- RE: [cgal-discuss] advice about CGAL Delaunay Triangulation, Kwok Jasper, 02/03/2009
