- To:
- Subject: Re: [cgal-discuss] compile an example code on win32 to produce
- Date: Wed, 04 Feb 2009 08:17:46 +0100
Hello,
instead of trying to hack up things you should try to understand
what makes that the libraries didn't get built on your machines.
We tested it heavily, so I am sure you do something wrong.
Did you follow the installation instructions? Did it build
you any libraries at all?
andreas
- [cgal-discuss] compile an example code on win32 to produce stand-alone binary, Qianqian Fang, 02/02/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, wangk0705, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Kye Wong, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Andreas Fabri, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Mahmood Naderan, 02/05/2009
