- To:
- Subject: Re: [cgal-discuss] compile an example code on win32 to produce
- Date: Wed, 4 Feb 2009 15:40:08 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=XUdXNSRIz6r2B+NDSB0nCSCb4kFhJOJgiVi9xtKgy8m6le30I3Oi2BQUo6duc5EjRN A9o9gwaD3H/5AOh36Kw0r9naUMXIizdJ31nP/8kpRZPJsNESkC72liMIrZ/dLtwsa7Rj xO5zavOjM48z8UTUaaoPBXFWvG7ibxeweCKvo=
I attached all the variables set in Cmake gui,would u pls help me to find the problem?
Thanks very much!
On Wed, Feb 4, 2009 at 3:26 PM, Kye Wong <> wrote:
Hi!yes,i've tried to build the .lib files many times and can only get lib files like: CGAL-vc80-mt-gd.lib,CGAL_PDB-vc80-mt-gd.lib, CGAL_ImageIO-vc80-mt-gd.lib,CGAL_Core-vc80-mt-gd.lib and so on.I've tried to follow every step in the installation manual and could not get the reason why I can not get the ***-sgd.lib.So could you pls give me some hint on how to set or modify the flags in Cmake-gui and how to build ALL-BUILD.proj in VS2005?Thanks for your help!--On Wed, Feb 4, 2009 at 3:17 PM, Andreas Fabri <> wrote:
Hello,
instead of trying to hack up things you should try to understand
what makes that the libraries didn't get built on your machines.
We tested it heavily, so I am sure you do something wrong.
Did you follow the installation instructions? Did it build
you any libraries at all?
andreas
Kye Wong
Kye Wong
Desktop.rar
Description: Binary data
- [cgal-discuss] compile an example code on win32 to produce stand-alone binary, Qianqian Fang, 02/02/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, wangk0705, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Kye Wong, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Andreas Fabri, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Mahmood Naderan, 02/05/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/06/2009
