cgal-discuss - Re: [cgal-discuss] compile an example code on win32 to produce
  • To:
  • Subject: Re: [cgal-discuss] compile an example code on win32 to produce
  • Date: Wed, 4 Feb 2009 15:26:43 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ZU3/Sg7zWpDASSbJSfdWfx0Ol5CqUfabcOj/0WjN0aQFmoEHCgRLFgrw3c02L6+HrO AeXDck813rGCEG/e/YmgZ2cdJHunPRA/eXyYQCC79YYPrbbT1n9k4VAgYK+bxMr8c9tu vKIwEMRpvQ0yrh7D3GAzxTx8ysB8g4Lwqip3M=
Hi!
yes,i've tried to build the .lib files many times and can only get lib files like: CGAL-vc80-mt-gd.lib,CGAL_PDB-vc80-mt-gd.lib, CGAL_ImageIO-vc80-mt-gd.lib,CGAL_Core-vc80-mt-gd.lib and so on.
I've tried to follow every step in the installation manual and could not get the reason why I can not get the ***-sgd.lib.
So could you pls give me some hint on how to set or modify the flags in Cmake-gui and how to build ALL-BUILD.proj in VS2005?
Thanks for your help!
On Wed, Feb 4, 2009 at 3:17 PM, Andreas Fabri <> wrote:
Hello,
instead of trying to hack up things you should try to understand
what makes that the libraries didn't get built on your machines.
We tested it heavily, so I am sure you do something wrong.
Did you follow the installation instructions?  Did it build
you any libraries at all?
andreas
Kye Wong
