- To:
- Subject: Re: [cgal-discuss] compile an example code on win32 to produce
- Date: Wed, 4 Feb 2009 10:41:34 +0100
On Wednesday 04 February 2009 10:14:20 Andreas Fabri wrote:
> Kye Wong wrote:
> > Hi!
> > yes,i've tried to build the .lib files many times and can only get lib
> > files like: CGAL-vc80-mt-gd.lib,CGAL_PDB-vc80-mt-gd.lib,
> > CGAL_ImageIO-vc80-mt-gd.lib,CGAL_Core-vc80-mt-gd.lib and so on.
> > I've tried to follow every step in the installation manual and could not
> > get the reason why I can not get the ***-sgd.lib.
> Hello Kye,
> If you want to use the static runtime, you have to change
> the compiler options /MD and MDd to /MT and MTd
> the CMAKE_CXX_FLAGS_DEBUG and CMAKE_CXX_FLAGS_RELEASE
That setup is not really supported by our cmake scripts: even if the flags
are
changed, the libraries name remain suffixed by -mt and -mt-gd. Kye, you will
need to rename the libraries to "-s" and "-sgd", by hand.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] compile an example code on win32 to produce stand-alone binary, Qianqian Fang, 02/02/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, wangk0705, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Kye Wong, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Andreas Fabri, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Mahmood Naderan, 02/05/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/06/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Kye Wong, 02/07/2009
