- To:
- Subject: Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?
- Date: Thu, 12 Feb 2009 00:13:38 +0100
Daniel,
thanks for your reply. Your link is what I am looking for :)
I realized that I indeed need a delaunay triangulation and not its dual,
the voronoi diagram, so the manual helps alot.
Thanks,
Tom
schrieb:
>> Ideally I would like to get back a type of mine (which should extend
>> Vertex_handle I guess) in which I could attach some information to a
>> vertex in
>> the diagram. Is there a way to achive this? It would be really nice if you
>> could point me in the right direction.
> This section of the manual was very helpful in my case:
> 29.11 Flexibility: Using Customized Vertices and Faces
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_29.11
> See the example "Adding colors".
> Best,
> Daniel
> Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
> ------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
- [cgal-discuss] Own Types as Sites in a voronoi diagram?, 2voodoo, 02/11/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, daniel . duque, 02/11/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Tom Kazimiers, 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Laurent Rineau (GeometryFactory), 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Andreas Fabri, 02/12/2009
- [cgal-discuss] "Easy" Nearest vertex location query in constrained delaunay triangulation?, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Mariette Yvinec, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Andreas Fabri, 02/17/2009
