- To:
- Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
- Date: Fri, 13 Feb 2009 10:11:51 +0100
Mariette Yvinec schrieb:
> Tom Kazimiers wrote:
>> Hello,
>> as I am relatively new to CGAL I am not very familiar with some concepts
>> or design decisions taken.
>> For example have I currently the problem (or wish :P ) to make fast
>> "nearest vertex queries" on constrained delaunay triangulations.
>> In the manual I found a "nearest_vertex ( Point p, Face_handle
>> f=Face_handle())" method only for
>> CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I would need
>> in a constrained delaunay triangulation. Since I did not find it I
>> implemented it in the following way:
>> // Typedefs CGAL
>> struct K :
>> CGAL::Exact_predicates_inexact_constructions_kernel {};
>> typedef
>> CGAL::Constrained_triangulation_face_base_2<K> Fb;
>> typedef CGAL::Exact_predicates_tag
>> Itag;
>> typedef CGAL::Triangulation_data_structure_2 <
>> CGALLaunchSite<>, Fb > Tds;
>> typedef CGAL::Constrained_Delaunay_triangulation_2<K,
>> Tds, Itag> CDT;
>> typedef CDT::Vertex_handle Vertex_handle;
>> typedef CDT::Face_handle Face_handle;
>> typedef CDT::Point PointCDT;
>> typedef K::Vector_2 VectorCGAL;
>> // Nearest vertex query
>> PointCDT cgal_pos(position.x(), position.z());
>> Face_handle handle =
>> m_cdt.locate(cgal_pos);
>> Vertex_handle v0 =
>> handle->vertex(0);
>> Vertex_handle v1 = handle->vertex(1);
>> Vertex_handle v2 = handle->vertex(2);
>> VectorCGAL vec0(v0->point(), cgal_pos);
>> VectorCGAL vec1(v1->point(), cgal_pos);
>> VectorCGAL vec2(v2->point(), cgal_pos);
>> PrecisionType distance0 =
>> vec0.squared_length();
>> PrecisionType distance1 = vec1.squared_length();
>> PrecisionType distance2 = vec2.squared_length();
>> if (distance0 < distance1) {
>> if (distance0 < distance2) {
>> return &*v0;
>> } else {
>> return &*v2;
>> } else {
>> if (distance1 < distance2) {
>> return &*v1;
>> } else {
>> return &*v2;
>> Is there any more easy or "convenient" way to do this? I ask since a
>> similar method exists for the triangulation without constrains.
>> Thanks again and in advance,
>> I hope that I did not miss anything in the manual :),
>> Tom
>> P. s.: Is there a way to make a constrained delaunay "terrain" (e. g. a
>> CDT with elevation, but that is only in XY space delaunay)?
> your solution is oversimplified because the nearest vertex need not
> be a vertex of the face including the query location.
> The CGAL traits class Triangulation_euclidean_traits_xy_2
> is designed to compute the elevation of
> the Delaunay triangulation in xy space of 3d points.
> It will lack of intersection test to compute a constrained Delaunay
> triangulation in xy space.
Mariette,
thank you for your answer. Why does the nearest vertex not need to be a
vertex of the face?
If the (2D-) point is included in a face the nearest vertex can only be
part of it, could't it? If not, where could the nearest vertex be?
(to clarify, I ment 2D space with a non-intersecting mesh - sorry, I did
not say this before)
I also found the the traits class you mentioned (it was used in the
terrain example), but I see no way
to insert it as a parameter for a constrained delaunay triangulation.
Thanks and regards,
Tom
- [cgal-discuss] Own Types as Sites in a voronoi diagram?, 2voodoo, 02/11/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, daniel . duque, 02/11/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Tom Kazimiers, 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Laurent Rineau (GeometryFactory), 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Andreas Fabri, 02/12/2009
- [cgal-discuss] "Easy" Nearest vertex location query in constrained delaunay triangulation?, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Mariette Yvinec, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Andreas Fabri, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Damian Sheehy, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Tom Kazimiers, 02/18/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Mariette Yvinec, 02/18/2009
