cgal-discuss - Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
  • To:
  • Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
  • Date: Tue, 17 Feb 2009 16:32:27 +0100
Hi,
sorry to come back on this, but my question why my solution to get the
nearest vertex to a given position
in a constrained delaunay triangulation is oversimplified is not clear
to me.
Mariette said that the is not said that the nearest vertex to a given
position has not to be a vertex of the face
I get by using "locate(position)". How can this be if it is a 2D
triangulation?
Thanks in advance and regards,
Tom
Tom Kazimiers schrieb:
> Mariette Yvinec schrieb:
>> Tom Kazimiers wrote:
>>> Hello,
>>> as I am relatively new to CGAL I am not very familiar with some concepts
>>> or design decisions taken.
>>> For example have I currently the problem (or wish :P ) to make fast
>>> "nearest vertex queries" on constrained delaunay triangulations.
>>> In the manual I found a "nearest_vertex ( Point p, Face_handle
>>> f=Face_handle())" method only for
>>> CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I would need
>>> in a constrained delaunay triangulation. Since I did not find it I
>>> implemented it in the following way:
>>> // Typedefs CGAL
>>> struct K :
>>> CGAL::Exact_predicates_inexact_constructions_kernel {};
>>> typedef
>>> CGAL::Constrained_triangulation_face_base_2<K> Fb;
>>> typedef CGAL::Exact_predicates_tag
>>> Itag;
>>> typedef CGAL::Triangulation_data_structure_2 <
>>> CGALLaunchSite<>, Fb > Tds;
>>> typedef CGAL::Constrained_Delaunay_triangulation_2<K,
>>> Tds, Itag> CDT;
>>> typedef CDT::Vertex_handle Vertex_handle;
>>> typedef CDT::Face_handle Face_handle;
>>> typedef CDT::Point PointCDT;
>>> typedef K::Vector_2 VectorCGAL;
>>> // Nearest vertex query
>>> PointCDT cgal_pos(position.x(), position.z());
>>> Face_handle handle =
>>> m_cdt.locate(cgal_pos);
>>> Vertex_handle v0 =
>>> handle->vertex(0);
>>> Vertex_handle v1 = handle->vertex(1);
>>> Vertex_handle v2 = handle->vertex(2);
>>> VectorCGAL vec0(v0->point(), cgal_pos);
>>> VectorCGAL vec1(v1->point(), cgal_pos);
>>> VectorCGAL vec2(v2->point(), cgal_pos);
>>> PrecisionType distance0 =
>>> vec0.squared_length();
>>> PrecisionType distance1 = vec1.squared_length();
>>> PrecisionType distance2 = vec2.squared_length();
>>> if (distance0 < distance1) {
>>> if (distance0 < distance2) {
>>> return &*v0;
>>> } else {
>>> return &*v2;
>>> } else {
>>> if (distance1 < distance2) {
>>> return &*v1;
>>> } else {
>>> return &*v2;
>>> Is there any more easy or "convenient" way to do this? I ask since a
>>> similar method exists for the triangulation without constrains.
>>> Thanks again and in advance,
>>> I hope that I did not miss anything in the manual :),
>>> Tom
>>> P. s.: Is there a way to make a constrained delaunay "terrain" (e. g. a
>>> CDT with elevation, but that is only in XY space delaunay)?
>> your solution is oversimplified because the nearest vertex need not
>> be a vertex of the face including the query location.
>> The CGAL traits class Triangulation_euclidean_traits_xy_2
>> is designed to compute the elevation of
>> the Delaunay triangulation in xy space of 3d points.
>> It will lack of intersection test to compute a constrained Delaunay
>> triangulation in xy space.
> Mariette,
> thank you for your answer. Why does the nearest vertex not need to be a
> vertex of the face?
> If the (2D-) point is included in a face the nearest vertex can only be
> part of it, could't it? If not, where could the nearest vertex be?
> (to clarify, I ment 2D space with a non-intersecting mesh - sorry, I did
> not say this before)
> I also found the the traits class you mentioned (it was used in the
> terrain example), but I see no way
> to insert it as a parameter for a constrained delaunay triangulation.
> Thanks and regards,
> Tom
