cgal-discuss - Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
  • To:
  • Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
  • Date: Fri, 13 Feb 2009 09:39:40 +0100
Tom Kazimiers wrote:
Hello,
as I am relatively new to CGAL I am not very familiar with some concepts
or design decisions taken.
For example have I currently the problem (or wish :P ) to make fast
"nearest vertex queries" on constrained delaunay triangulations.
In the manual I found a "nearest_vertex ( Point p, Face_handle
f=Face_handle())" method only for
CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I would need
in a constrained delaunay triangulation. Since I did not find it I
implemented it in the following way:
// Typedefs CGAL
struct K :
CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef
CGAL::Constrained_triangulation_face_base_2<K> Fb;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Triangulation_data_structure_2 <
CGALLaunchSite<>, Fb > Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<K,
Tds, Itag> CDT;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Face_handle Face_handle;
typedef CDT::Point PointCDT;
typedef K::Vector_2 VectorCGAL;
// Nearest vertex query
PointCDT cgal_pos(position.x(), position.z());
Face_handle handle = m_cdt.locate(cgal_pos);
Vertex_handle v0 = handle->vertex(0);
Vertex_handle v1 = handle->vertex(1);
Vertex_handle v2 = handle->vertex(2);
VectorCGAL vec0(v0->point(), cgal_pos);
VectorCGAL vec1(v1->point(), cgal_pos);
VectorCGAL vec2(v2->point(), cgal_pos);
PrecisionType distance0 = vec0.squared_length();
PrecisionType distance1 = vec1.squared_length();
PrecisionType distance2 = vec2.squared_length();
if (distance0 < distance1) {
if (distance0 < distance2) {
return &*v0;
} else {
return &*v2;
} else {
if (distance1 < distance2) {
return &*v1;
} else {
return &*v2;
Is there any more easy or "convenient" way to do this? I ask since a
similar method exists for the triangulation without constrains.
Thanks again and in advance,
I hope that I did not miss anything in the manual :),
Tom
P. s.: Is there a way to make a constrained delaunay "terrain" (e. g. a
CDT with elevation, but that is only in XY space delaunay)?
your solution is oversimplified because the nearest vertex need not
be a vertex of the face including the query location.
The CGAL traits class Triangulation_euclidean_traits_xy_2
is designed to compute the elevation of
the Delaunay triangulation in xy space of 3d points.
It will lack of intersection test to compute a constrained Delaunay
triangulation in xy space.
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
