- To:
- Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained
- Date: Tue, 17 Feb 2009 17:27:01 +0100
Hi Tom,
If you have a constraint running from San Francisco to New York City,
and you sit on a vertex close to the constraint somewhere in the middle
of the US and the geometrically closest vertex is on the other side of
this constaint, then the function closest_vertex gives you either a
vertex on your side or even the vertex of SF or NYC, but not what you
are looking for.
andreas
Tom Kazimiers wrote:
Hi,
sorry to come back on this, but my question why my solution to get the
nearest vertex to a given position
in a constrained delaunay triangulation is oversimplified is not clear
to me.
Mariette said that the is not said that the nearest vertex to a given
position has not to be a vertex of the face
I get by using "locate(position)". How can this be if it is a 2D
triangulation?
Thanks in advance and regards,
Tom
Tom Kazimiers schrieb:
Mariette Yvinec schrieb:
Tom Kazimiers wrote:Mariette,
Hello,your solution is oversimplified because the nearest vertex need not
as I am relatively new to CGAL I am not very familiar with some concepts
or design decisions taken.
For example have I currently the problem (or wish :P ) to make fast
"nearest vertex queries" on constrained delaunay triangulations.
In the manual I found a "nearest_vertex ( Point p, Face_handle
f=Face_handle())" method only for
CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I would need
in a constrained delaunay triangulation. Since I did not find it I
implemented it in the following way:
// Typedefs CGAL
struct K :
CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef
CGAL::Constrained_triangulation_face_base_2<K> Fb;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Triangulation_data_structure_2 <
CGALLaunchSite<>, Fb > Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<K,
Tds, Itag> CDT;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Face_handle Face_handle;
typedef CDT::Point PointCDT;
typedef K::Vector_2 VectorCGAL;
// Nearest vertex query
PointCDT cgal_pos(position.x(), position.z());
Face_handle handle =
m_cdt.locate(cgal_pos);
Vertex_handle v0 =
handle->vertex(0);
Vertex_handle v1 = handle->vertex(1);
Vertex_handle v2 = handle->vertex(2);
VectorCGAL vec0(v0->point(), cgal_pos);
VectorCGAL vec1(v1->point(), cgal_pos);
VectorCGAL vec2(v2->point(), cgal_pos);
PrecisionType distance0 =
vec0.squared_length();
PrecisionType distance1 = vec1.squared_length();
PrecisionType distance2 = vec2.squared_length();
if (distance0 < distance1) {
if (distance0 < distance2) {
return &*v0;
} else {
return &*v2;
} else {
if (distance1 < distance2) {
return &*v1;
} else {
return &*v2;
Is there any more easy or "convenient" way to do this? I ask since a
similar method exists for the triangulation without constrains.
Thanks again and in advance,
I hope that I did not miss anything in the manual :),
Tom
P. s.: Is there a way to make a constrained delaunay "terrain" (e. g. a
CDT with elevation, but that is only in XY space delaunay)?
be a vertex of the face including the query location.
The CGAL traits class Triangulation_euclidean_traits_xy_2
is designed to compute the elevation of
the Delaunay triangulation in xy space of 3d points.
It will lack of intersection test to compute a constrained Delaunay
triangulation in xy space.
thank you for your answer. Why does the nearest vertex not need to be a
vertex of the face?
If the (2D-) point is included in a face the nearest vertex can only be
part of it, could't it? If not, where could the nearest vertex be?
(to clarify, I ment 2D space with a non-intersecting mesh - sorry, I did
not say this before)
I also found the the traits class you mentioned (it was used in the
terrain example), but I see no way
to insert it as a parameter for a constrained delaunay triangulation.
Thanks and regards,
Tom
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, (continued)
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, daniel . duque, 02/11/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Tom Kazimiers, 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Laurent Rineau (GeometryFactory), 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Andreas Fabri, 02/12/2009
- [cgal-discuss] "Easy" Nearest vertex location query in constrained delaunay triangulation?, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Mariette Yvinec, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Andreas Fabri, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Damian Sheehy, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Tom Kazimiers, 02/18/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Mariette Yvinec, 02/18/2009
