- To:
- Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in
- Date: Wed, 18 Feb 2009 03:03:56 +0100
Damien,
thanks for your intrusion and clarification :)
Now, the problem is clear and I am happy that it is not a problem for me
since I needed not the geometrically absolute next vertex, but the
geometrically next vertex respecting constrains. So in your example I
would be lucky if NY is the result of the query. It seems that I made
myself not very clear in the first place, infact, what should one think
else by reading "nearest vertex" :) So thanks for the explanation and
the patience, I will surely need this at another place in my application.
Thanks and regards,
Tom
Damian Sheehy schrieb:
> Hi Tom,
> Pardon my intrusion - I think the attached image will help clarify
> what Andreas is saying.
> The thing to bear in mind here is the fact that a constrained Delaunay
> triangulation is not fully Delaunay.
> In other words, some (or all!) triangles in the triangulation may not
> respect the Delaunay (empty circumcircle) property.
> This is the case in the attached image; Denver is within the
> circumcircle of the larger triangle.
> You can clearly see that Denver is the nearest vertex to the query
> point, however if you were to base your solution on the nearest vertex
> of the enclosing triangle the result would be New York, which is wrong.
> To get around this problem you can do the following; make a copy of
> your constrained triangulation. Remove the constraints from the copy,
> and then you can use it to perform nearest vertex queries.
> I hope this helps.
> Damian
> On Tue, Feb 17, 2009 at 1:29 PM, Tom Kazimiers
> <mailto:>>
> wrote:
> Hi Andreas,
> thank you for your reply. If I sit on a vertex close to the constraint
> isn't it the case that I get
> a face that is on the constraints side the vertex is in? Actually, I
> wonder if one face can be "crossed"
> by a constraint so that some vertices are on one constraint side and
> some on the other. I guess not,
> since all faces are delaunay triangles. So if I get a face lieing
> to the
> "left" of the constraint through a
> vertex lieing to the "left" of the contraint, all vertices of the face
> should lie on the "left" side of the
> constraint, don't they?
> The solution I currently use relies at least on this assumption
> -if this
> is not true, it will not safely work, true.
> A function called "closesst_vertex" does not exist for constrained
> delaunay triangulations, so I go through
> the face to the vertices.
> But, maybe I understood something wrong :)
> bye, and thanks,
> Tom
> Andreas Fabri schrieb:
> > Hi Tom,
> > If you have a constraint running from San Francisco to New York
> City,
> > and you sit on a vertex close to the constraint somewhere in the
> middle
> > of the US and the geometrically closest vertex is on the other
> side of
> > this constaint, then the function closest_vertex gives you either a
> > vertex on your side or even the vertex of SF or NYC, but not
> what you
> > are looking for.
> > andreas
> > Tom Kazimiers wrote:
> >> Hi,
> >> sorry to come back on this, but my question why my solution to
> get the
> >> nearest vertex to a given position
> >> in a constrained delaunay triangulation is oversimplified is
> not clear
> >> to me.
> >> Mariette said that the is not said that the nearest vertex to a
> given
> >> position has not to be a vertex of the face
> >> I get by using "locate(position)". How can this be if it is a 2D
> >> triangulation?
> >> Thanks in advance and regards,
> >> Tom
> >> Tom Kazimiers schrieb:
> >>>>> Hello,
> >>>>> as I am relatively new to CGAL I am not very familiar with some
> >>>>> concepts
> >>>>> or design decisions taken.
> >>>>> For example have I currently the problem (or wish :P ) to
> make fast
> >>>>> "nearest vertex queries" on constrained delaunay triangulations.
> >>>>> In the manual I found a "nearest_vertex ( Point p, Face_handle
> >>>>> f=Face_handle())" method only for
> >>>>> CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I
> >>>>> would need
> >>>>> in a constrained delaunay triangulation. Since I did not
> find it I
> >>>>> implemented it in the following way:
> >>>>> // Typedefs CGAL
> >>>>> struct K :
> >>>>> CGAL::Exact_predicates_inexact_constructions_kernel {};
> >>>>> typedef
> >>>>> CGAL::Constrained_triangulation_face_base_2<K>
> Fb;
> >>>>> typedef
> >>>>> CGAL::Exact_predicates_tag
> Itag;
> >>>>> typedef
> CGAL::Triangulation_data_structure_2 <
> >>>>> CGALLaunchSite<>, Fb > Tds;
> >>>>> typedef
> CGAL::Constrained_Delaunay_triangulation_2<K,
> >>>>> Tds, Itag> CDT;
> >>>>> typedef CDT::Vertex_handle
> >>>>> Vertex_handle;
> >>>>> typedef CDT::Face_handle Face_handle;
> >>>>> typedef CDT::Point
> PointCDT;
> >>>>> typedef K::Vector_2
> VectorCGAL;
> >>>>> // Nearest vertex query
> >>>>> PointCDT cgal_pos(position.x(), position.z());
> >>>>> Face_handle handle =
> >>>>> m_cdt.locate(cgal_pos);
> >>>>> Vertex_handle v0 =
> >>>>> handle->vertex(0);
> >>>>> Vertex_handle v1 = handle->vertex(1);
> >>>>> Vertex_handle v2 = handle->vertex(2);
> >>>>> VectorCGAL vec0(v0->point(),
> >>>>> cgal_pos);
> >>>>> VectorCGAL vec1(v1->point(), cgal_pos);
> >>>>> VectorCGAL vec2(v2->point(), cgal_pos);
> >>>>> PrecisionType distance0 =
> >>>>> vec0.squared_length();
> >>>>> PrecisionType distance1 = vec1.squared_length();
> >>>>> PrecisionType distance2 = vec2.squared_length();
> >>>>> if (distance0 < distance1) {
> >>>>> if (distance0 < distance2) {
> >>>>> return &*v0;
> >>>>> } else {
> >>>>> return &*v2;
> >>>>> } else {
> >>>>> if (distance1 < distance2) {
> >>>>> return &*v1;
> >>>>> } else {
> >>>>> return &*v2;
> >>>>> Is there any more easy or "convenient" way to do this? I ask
> since a
> >>>>> similar method exists for the triangulation without constrains.
> >>>>> Thanks again and in advance,
> >>>>> I hope that I did not miss anything in the manual :),
> >>>>> Tom
> >>>>> P. s.: Is there a way to make a constrained delaunay
> "terrain" (e.
> >>>>> g. a
> >>>>> CDT with elevation, but that is only in XY space delaunay)?
> >>>> your solution is oversimplified because the nearest vertex
> need not
> >>>> be a vertex of the face including the query location.
> >>>> The CGAL traits class Triangulation_euclidean_traits_xy_2
> >>>> is designed to compute the elevation of
> >>>> the Delaunay triangulation in xy space of 3d points.
> >>>> It will lack of intersection test to compute a constrained
> Delaunay
> >>>> triangulation in xy space.
> >>> Mariette,
> >>> thank you for your answer. Why does the nearest vertex not
> need to be a
> >>> vertex of the face?
> >>> If the (2D-) point is included in a face the nearest vertex
> can only be
> >>> part of it, could't it? If not, where could the nearest vertex be?
> >>> (to clarify, I ment 2D space with a non-intersecting mesh -
> sorry, I
> >>> did
> >>> not say this before)
> >>> I also found the the traits class you mentioned (it was used
> in the
> >>> terrain example), but I see no way
> >>> to insert it as a parameter for a constrained delaunay
> triangulation.
> >>> Thanks and regards,
> >>> Tom
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, (continued)
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Tom Kazimiers, 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Laurent Rineau (GeometryFactory), 02/12/2009
- Re: [cgal-discuss] Own Types as Sites in a voronoi diagram?, Andreas Fabri, 02/12/2009
- [cgal-discuss] "Easy" Nearest vertex location query in constrained delaunay triangulation?, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Mariette Yvinec, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/13/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Tom Kazimiers, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in constrained, Andreas Fabri, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Damian Sheehy, 02/17/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Tom Kazimiers, 02/18/2009
- Re: [cgal-discuss] "Easy" Nearest vertex location query in, Mariette Yvinec, 02/18/2009
