cgal-discuss - Re: [cgal-discuss] "Easy" Nearest vertex location query in
  • To:
  • Subject: Re: [cgal-discuss] "Easy" Nearest vertex location query in
  • Date: Wed, 18 Feb 2009 12:53:22 +0100
Mariette,
thanks for your further explanations. Indeed, I was wrong and did not
see this issue.
The demomstration through the voronoi diagram makes everyting clear.
The hint of using get_boundary_of_conflicts(Point q, .......) works
pretty well and yes,
I was looking for the nearest visible neighbor.
Thanks and regards,
Tom
Mariette Yvinec schrieb:
> Sorry to disturb,
> but this is wrong.
> Even within a Delaunay triangulation (without any constraint)
> you may find query points whose nearest site is not a vertex
> of the triangle in which they lie.
> In the joint the example, the blue lines draw the Delaunay triangulation
> while the red line draw the Voronoi diagram (showing for each site,
> its set of closest points).
> Every query point in the grey area has for nearest neighbor
> a site which is not a vertex in its cell.
> Furthermore,
> it seems that what you are looking for is not
> the nearest neighbor but the nearest visible
> neighbor...
> What is true is that if you were inserting your query point
> in the constrained Delaunay,
> the new triangulation would have an edge
> between your query point and its nearest visible vertex.
> So what you can do, is to use the member function
> get_boundary_of_conflicts(Point q, .......),
> where q is your query point,
> look at all vertices on the output boundary
> and get the closest to q :
> this is the nearest visible vertex from q.
> Tom Kazimiers wrote:
>> Damien,
>> thanks for your intrusion and clarification :)
>> Now, the problem is clear and I am happy that it is not a problem for me
>> since I needed not the geometrically absolute next vertex, but the
>> geometrically next vertex respecting constrains. So in your example I
>> would be lucky if NY is the result of the query. It seems that I made
>> myself not very clear in the first place, infact, what should one think
>> else by reading "nearest vertex" :) So thanks for the explanation and
>> the patience, I will surely need this at another place in my application.
>> Thanks and regards,
>> Tom
>> Damian Sheehy schrieb:
>>> Hi Tom,
>>> Pardon my intrusion - I think the attached image will help clarify
>>> what Andreas is saying.
>>> The thing to bear in mind here is the fact that a constrained Delaunay
>>> triangulation is not fully Delaunay.
>>> In other words, some (or all!) triangles in the triangulation may not
>>> respect the Delaunay (empty circumcircle) property.
>>> This is the case in the attached image; Denver is within the
>>> circumcircle of the larger triangle.
>>> You can clearly see that Denver is the nearest vertex to the query
>>> point, however if you were to base your solution on the nearest vertex
>>> of the enclosing triangle the result would be New York, which is wrong.
>>> To get around this problem you can do the following; make a copy of
>>> your constrained triangulation. Remove the constraints from the copy,
>>> and then you can use it to perform nearest vertex queries.
>>> I hope this helps.
>>> Damian
>>> On Tue, Feb 17, 2009 at 1:29 PM, Tom Kazimiers
>>> <mailto:>>
>>> wrote:
>>> Hi Andreas,
>>> thank you for your reply. If I sit on a vertex close to the constraint
>>> isn't it the case that I get
>>> a face that is on the constraints side the vertex is in? Actually, I
>>> wonder if one face can be "crossed"
>>> by a constraint so that some vertices are on one constraint side and
>>> some on the other. I guess not,
>>> since all faces are delaunay triangles. So if I get a face lieing
>>> to the
>>> "left" of the constraint through a
>>> vertex lieing to the "left" of the contraint, all vertices of the face
>>> should lie on the "left" side of the
>>> constraint, don't they?
>>> The solution I currently use relies at least on this assumption
>>> -if this
>>> is not true, it will not safely work, true.
>>> A function called "closesst_vertex" does not exist for constrained
>>> delaunay triangulations, so I go through
>>> the face to the vertices.
>>> But, maybe I understood something wrong :)
>>> bye, and thanks,
>>> Tom
>>> Andreas Fabri schrieb:
>>> > Hi Tom,
>>> > If you have a constraint running from San Francisco to New York
>>> City,
>>> > and you sit on a vertex close to the constraint somewhere in the
>>> middle
>>> > of the US and the geometrically closest vertex is on the other
>>> side of
>>> > this constaint, then the function closest_vertex gives you either a
>>> > vertex on your side or even the vertex of SF or NYC, but not
>>> what you
>>> > are looking for.
>>> > andreas
>>> >> Hi,
>>> >> sorry to come back on this, but my question why my solution to
>>> get the
>>> >> nearest vertex to a given position
>>> >> in a constrained delaunay triangulation is oversimplified is
>>> not clear
>>> >> to me.
>>> >> Mariette said that the is not said that the nearest vertex to a
>>> given
>>> >> position has not to be a vertex of the face
>>> >> I get by using "locate(position)". How can this be if it is a 2D
>>> >> triangulation?
>>> >> Thanks in advance and regards,
>>> >> Tom
>>> >>>>> Hello,
>>> >>>>> as I am relatively new to CGAL I am not very familiar with some
>>> >>>>> concepts
>>> >>>>> or design decisions taken.
>>> >>>>> For example have I currently the problem (or wish :P ) to
>>> make fast
>>> >>>>> "nearest vertex queries" on constrained delaunay triangulations.
>>> >>>>> In the manual I found a "nearest_vertex ( Point p, Face_handle
>>> >>>>> f=Face_handle())" method only for
>>> >>>>> CGAL::Delaunay_triangulation_2<Traits,Tds> and this is what I
>>> >>>>> would need
>>> >>>>> in a constrained delaunay triangulation. Since I did not
>>> find it I
>>> >>>>> implemented it in the following way:
>>> >>>>> // Typedefs CGAL
>>> >>>>> struct K :
>>> >>>>> CGAL::Exact_predicates_inexact_constructions_kernel {};
>>> >>>>> typedef
>>> >>>>> CGAL::Constrained_triangulation_face_base_2<K>
>>> Fb;
>>> >>>>> typedef
>>> >>>>> CGAL::Exact_predicates_tag
>>> Itag;
>>> >>>>> typedef
>>> CGAL::Triangulation_data_structure_2 <
>>> >>>>> CGALLaunchSite<>, Fb > Tds;
>>> >>>>> typedef
>>> CGAL::Constrained_Delaunay_triangulation_2<K,
>>> >>>>> Tds, Itag> CDT;
>>> >>>>> typedef CDT::Vertex_handle
>>> >>>>> Vertex_handle;
>>> >>>>> typedef CDT::Face_handle Face_handle;
>>> >>>>> typedef CDT::Point
>>> PointCDT;
>>> >>>>> typedef K::Vector_2
>>> VectorCGAL;
>>> >>>>> // Nearest vertex query
>>> >>>>> PointCDT cgal_pos(position.x(), position.z());
>>> >>>>> Face_handle handle =
>>> >>>>> m_cdt.locate(cgal_pos);
>>> >>>>> Vertex_handle v0 =
>>> >>>>> handle->vertex(0);
>>> >>>>> Vertex_handle v1 = handle->vertex(1);
>>> >>>>> Vertex_handle v2 = handle->vertex(2);
>>> >>>>> VectorCGAL vec0(v0->point(),
>>> >>>>> cgal_pos);
>>> >>>>> VectorCGAL vec1(v1->point(), cgal_pos);
>>> >>>>> VectorCGAL vec2(v2->point(), cgal_pos);
>>> >>>>> PrecisionType distance0 =
>>> >>>>> vec0.squared_length();
>>> >>>>> PrecisionType distance1 = vec1.squared_length();
>>> >>>>> PrecisionType distance2 = vec2.squared_length();
>>> >>>>> if (distance0 < distance1) {
>>> >>>>> if (distance0 < distance2) {
>>> >>>>> return &*v0;
>>> >>>>> } else {
>>> >>>>> return &*v2;
>>> >>>>> } else {
>>> >>>>> if (distance1 < distance2) {
>>> >>>>> return &*v1;
>>> >>>>> } else {
>>> >>>>> return &*v2;
>>> >>>>> Is there any more easy or "convenient" way to do this? I ask
>>> since a
>>> >>>>> similar method exists for the triangulation without constrains.
>>> >>>>> Thanks again and in advance,
>>> >>>>> I hope that I did not miss anything in the manual :),
>>> >>>>> Tom
>>> >>>>> P. s.: Is there a way to make a constrained delaunay
>>> "terrain" (e.
>>> >>>>> g. a
>>> >>>>> CDT with elevation, but that is only in XY space delaunay)?
>>> >>>> your solution is oversimplified because the nearest vertex
>>> need not
>>> >>>> be a vertex of the face including the query location.
>>> >>>> The CGAL traits class Triangulation_euclidean_traits_xy_2
>>> >>>> is designed to compute the elevation of
>>> >>>> the Delaunay triangulation in xy space of 3d points.
>>> >>>> It will lack of intersection test to compute a constrained
>>> Delaunay
>>> >>>> triangulation in xy space.
>>> >>> Mariette,
>>> >>> thank you for your answer. Why does the nearest vertex not
>>> need to be a
>>> >>> vertex of the face?
>>> >>> If the (2D-) point is included in a face the nearest vertex
>>> can only be
>>> >>> part of it, could't it? If not, where could the nearest vertex be?
>>> >>> (to clarify, I ment 2D space with a non-intersecting mesh -
>>> sorry, I
>>> >>> did
>>> >>> not say this before)
>>> >>> I also found the the traits class you mentioned (it was used
>>> in the
>>> >>> terrain example), but I see no way
>>> >>> to insert it as a parameter for a constrained delaunay
>>> triangulation.
>>> >>> Thanks and regards,
>>> >>> Tom
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
