- To:
- Subject: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
- Date: Fri, 5 Jun 2009 12:48:25 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type; b=MWo3ae4/8aFNWimEw/6GCZYYCpe3iVgWXqeVAGZULg/D6J7Z2c5M10/BN22bSDKLRTcD5fqfVKn+MQm9vI1lByzZIu7kop9adBCu0K+I+SpLgeo3DG9bfaaNIomPLawLLtWHMvw97nr9CArCRzr51Y8lvm/hmEvbSeqFP0aCyUU=;
Hi,
Has anyone successfully installed CGAL on IBM AIX systems?
I am trying to install CGAL 3.3.1 libraries on IBM AIX 5.3 system recently. The OS is 'powerpc_AIX-3.0, Compiler is GNU 4.1.2. The setup has been test OK. When I built CGAL libraries, I got lots of compiler errors. I attached two log files if you want to take a look at the errors. Thank you in advance.
Thanks,
-Shu |
install.log
Description: Binary data
compile.log
- [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, sye_01, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/05/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/07/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Joachim Reichel, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/09/2009
