- To:
- Subject: Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
- Date: Mon, 08 Jun 2009 18:32:07 +0200
Hi,
> Where should I put "export CXX=xlc ; cmake ; make"? Could you give me an
> exact procedure on how to do it?
this advice applies to CGAL 3.4 which uses cmake. Is there any reason
why you use the old CGAL 3.3.1?
There was a way to set the compiler in 3.3.1 as well. Probably you have
to set CXX (and maybe CC) before calling install_cgal.
Joachim
- [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, sye_01, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/05/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/07/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Joachim Reichel, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/09/2009
