cgal-discuss - Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
  • To:
  • Subject: Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
  • Date: Fri, 05 Jun 2009 22:26:28 +0200
  • Organization: INRIA
wrote:
Hi,
Has anyone successfully installed CGAL on IBM AIX systems?
I am trying to install CGAL 3.3.1 libraries on IBM AIX 5.3 system recently. The OS is 'powerpc_AIX-3.0, Compiler is GNU 4.1.2. The setup has been test OK. When I built CGAL libraries, I got lots of compiler errors. I attached two log files if you want to take a look at the errors. Thank you in advance.
/home/shuy/EMS/CGAL-3.3.1/ibmrs1/CGAL-3.3.1/include/CGAL/Point_3.h:145:
error: '100' cannot be used as a function
Smeels like some system header is defining a macro like "hz" to 100...
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
