cgal-discuss - Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
  • To:
  • Subject: Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
  • Date: Mon, 08 Jun 2009 15:08:28 +0200
  • Organization: INRIA
Did you try "export CXX=xlc ; cmake ; make" ?
Shu Ye wrote:
It looks like CGAL uses gcc by default. Actually I must use IBM 7.0 compiler (xlc) to be consistent with other software on IBM system. I need determine how to configure CGAL to build with xlc. Any suggestions on how to do it?
Thank you in advance,
Thanks,
-Shu
--- On *Sun, 6/7/09, Sylvain Pion
AIX 5.3
To:
Date: Sunday, June 7, 2009, 12:54 PM
My suggestion would be that you change all occurences of the word "hz"
to e.g. "hz_" in your own copy of CGAL.
I don't see a reasonable solution to work around this within CGAL.
Shu Ye wrote:
> Hi Sylvain,
> Thank you for taking a look at it. Do you have any suggestions on
how to fix it?
> Thanks,
> -Shu
> --- On *Fri, 6/5/09, Sylvain Pion
<http://us.mc592.mail.yahoo.com/mc/compose?>>/*
wrote:
> From: Sylvain Pion
on IBM
> AIX 5.3
> To:
> Date: Friday, June 5, 2009, 8:26 PM
</mc/compose?
wrote:
> > Hi,
> > Has anyone successfully installed CGAL on IBM AIX systems?
> > I am trying to install CGAL 3.3.1 libraries on IBM AIX 5.3
> system recently. The OS is 'powerpc_AIX-3.0, Compiler is GNU
4.1.2.
> The setup has been test OK. When I built CGAL libraries, I
got lots
> of compiler errors. I attached two log files if you want to
take a
> look at the errors. Thank you in advance.
> /home/shuy/EMS/CGAL-3.3.1/ibmrs1/CGAL-3.3.1/include/CGAL/Point_3.h:145:
> error: '100' cannot be used as a function
> Smeels like some system header is defining a macro like "hz"
to 100...
> -- Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
> -- You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
-- Sylvain Pion
Sylvain Pion
