cgal-discuss - Re: [cgal-discuss] Anonymous SVN access Jet fitting
  • To:
  • Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
  • Date: Tue, 13 Oct 2009 13:40:09 +0000
On Tuesday 13 October 2009 07:24:30 Marc Pouget wrote:
> Please give us more details about your expectations and experiments
> if you want some feedback
OK, bear with me then :-)
I want to estimate normals on digital surfaces obtained from a segmentation.
In our case, the digital surfaces are comprised of the surface-elements of
voxels, so the surfaces lie in-between the voxels. They are not sub-pixel
accurate by definition and thus typical stair-like artefacts are obvious.
Initial tests based on the Jet_fitting_3 example code for a polyhedral mesh
did not result in any good estimates even for large (32 vertices)
neighborhoods; the normal orientation varied a lot from vertex to
neighbouring
vertex even for quite smooth parts of my surface.
Therefore, I tested everything on a simple testcase, two plots of which are
attached to this mail:
On the plot "snapshot_plane.png" you see onto the side of a sampled plane,
which has the typical stair artefacts. A 3D view is in "snapshot_plane_2.png"
I hand crafted code to triangulate this plane to exclude any possible errors
in wrong triangulations, then fed the vertices and edges to a
CGAL::Polyhedron_incremental_builder_3 to build the polyhedron.
I based my code on the cgal jet fitting example "Mesh_estimation.cpp".
I randomly chose one vertex and put debug code into the
Monge_via_jet_fitting.h header to output the list of vertices considered.
These are drawn as blue '*' symbols around the vertex. This looks all ok.
Next, I examined the ouput of the monge fit for the chosen vertex. The
results
are the colored arrows which originate in the chosen vertex.
- the green arrow represents the TRUE normal of the plane as constructed
- the deep red arrow is the estimated normal using the vertex plus the
surrounding blue '*' points with the complete CGAL jet-fitting method
- the pink arrows are the maximal and minimal principal direction as given
by the monge fit procedure. You can see that they are off.
- the orange arrows look very much ok, and the orange normal is completely
correct (the sign doesn't matter of course):
These are just the eigenvectors obtained from the PCA analysis in the
code, the polynomial fitting results are _not_ considered
How can it be that I arrived at this result? At the moment I am suspecting a
bug in CGAL, but of course I cannot exclude a bug or thinking error on my
part; are there any requirements I might have disregarded? Any definitions of
angles etc. I might have used in the wrong way?
I'll be happy to send code along and try to reduce it to a more minimal
testcase if necessary; at the moment I pass data for visualization purposes
to
Matlab, so the code is run as a Matlab Mex file, therefor it's a bit "messy"
to debug for anyone not using Matlab.
Thanks for your time,
Thorben
Attachment: snapshot_plane.png
Description: PNG image
Attachment: snapshot_plane_2.png
