- To:
- Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
- Date: Wed, 14 Oct 2009 10:08:01 +0000
On Wednesday 14 October 2009 09:49:02 Marc Pouget wrote:
> Puzzling!
> can you try a real planar plane
Attached smooth_plane.png calls the same matlab interface function that I
used
in my previous experiments. That looks very much OK.
> and a simple smooth surface
> (parabolic cylinder or elliptic paraboloid there is a picture in the
> manual 53.2)
Attached file smooth_ellipsoid.png This looks ok as well.
> to see if the results are as expected and hence check
> there is not pb in the interface?
Cheers,
Thorben
Description: PNG image
- [cgal-discuss] Anonymous SVN access, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/15/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/19/2009
